Links to official tests that back up that up?
Here ya go. Figure 1 is the snip-it I posted, and was data from actual filter media testing. Then they modeled the efficiency vs loading they saw and verified thier model matched actual test data. See the section entitled "Three completely different explanations are possible for this behavior". Fact is, not all oil filters get more efficient as they load up.
https://www.geodict.com/Presentations/2013FiltechBeckerHahnLehmannWiegmannPaper.pdf
BTW - I've also seen other info (verified by testing) that said that captured debris can be dislodged from oil filters when there are increases in delta-p across the media. Makes sense that media can't hold every particle it captures when enough delta-p force across the media occurs. Some filters will obviously be better than others in this respect. And like mentioned, if a filter rates high in the ISO 4548-12 efficiency test then it's obviously holding captured particles well as the delta-p increases, otherwise it couldn't make the efficiency rating it ends up with.
