I already have a cordless 1/2" drive impact wrench, and I'm thinking about getting a cordless ratchet, 3/8" impact wrench, and either a drill driver or a 1/4" impact.
For the cordless ratchet I'm not sure if I should get the 3/8" or the 1/4" ratchet. I'm pretty set on the Milwaukee line and there's only a 5ft lb of torque difference between the 3/8" and 1/4", with the same RPM. I'm thinking it will probably be used mostly in tight spots and on smaller bolts, so I'm leaning towards the 1/4". 5 ft lb is a pretty negligble difference, and I can always break bolts loose and tighten them by hand.
I'm also thinking of getting a 3/8" impact wrench, and either a drill or 1/4" impact. However, I'm starting to realize they won't be as necessary the cordless ratchet. The 3/8" impact would be nice to break things loose that don't require the 1/2" impact, but need something stronger than 30-35ft lb. I could also use it to tighten down things in that range that don't need to be torqued.
As for the drill driver or 1/4" impact wrench, I'm not sure which one to get. They also have a 1/4" hex bit driver. I would mostly be using this to remove and reinstall screws or small bolts, mostly for dash/interior work. It would be nice to have variable speed, so I could reinstall screws and small bolts all the way without having to worry about breaking them. For example, dash/interior screws, or headlight bolts. I don't need a drill driver for drilling holes since I have a strong Dewalt for that, but would consider it just for the variable speed.
I'm only looking to use these tools for automotive purposes, there is no other intended use. Any suggestions, comments, experiences?
