Originally Posted By: m6pwr
FWIW, a guy on the VW TDI forum visited the diesel factory in Germany where the TDI diesel engine is made and was warned NOT to change the ff early (it was an oil made by FUCHS - the factory fill specialist - rather than Castrol, the service fill). Don't know about VW gassers like the OP's Tiguan.
VW Head Office is probably petrified about what certain North American VW dealers use for service lube for TDIs and gassers (i.e. API/ILSAC oils instead of anything resembling the ACEA specifications, let alone VW/Audi specs).
Things are way different now with new factory engines and modern oils. You can let it go MUCH further than what was considered smart years ago. 500 miles or even less was common.
I think this is commonly forgotten, along with the old advice of changing the factory fills early. While we in North America may have been quick to embrace thinner oils, we're certainly more reluctant to embrace the longer OCIs or dispense with concern over factory fills.
Personally, with respect to factory fill changing, if I were buying a new car, I'd follow the manual within limits. If it explicitly warned against changing the factory fill (or I knew from another source, like here, that there is a special fortified factory fill), I'd follow that rule. If it simply said it's not necessary, I'd be tempted to change early. I may be wrong; I may be right. I'm not married to that philosophy.
With respect to the metal flakes we see in the oil in the first change of a new car's oil, I agree with a couple points brought up here. First, I have seen such flecks. They are more noticeable with aftermarket rebuilds than they are with new cars. I also haven't seen a lot of brand new cars' first drains in the past few years, though, either. Secondly, I also agree with what some other posters here have said. If you're actually seeing glint in the oil, it's certainly large enough for the filter to pick up. If the filter didn't pick it up and it's still in the oil, my bet would be that the oil pickup isn't grabbing it and circulating it in the first place. Sure, I'd prefer it not be there, but if the filter didn't grab it and it's not circulating, is there any harm?
