Yes. That is true and what I was trying to say. In this case the CCS did not pass as a bill 10W. Only as a 15W. So regardless of how good the MRV may be assuming it would pass as a 10w. It still could only be a 15W.
I reference the pour point all the time. For example the 80w140 gear lube I use shows a PP of -33C, but 80W is a test conducted at -26C.No, because as already noted pumpability at very low temperatures is influenced by shear in the oil around the pump inlet. Tom's post describes this. Pour point was demonstrated to be an unreliable indicator of pumpability at low temperatures.
Definitely. But some engine failures in the 80s showed that it was unreliable. Even though the oil should have been pumpable it was not because when placed under shear at the pump inlet it would cause cavitation, as noted above.I reference the pour point all the time. For example the 80w140 gear lube I use shows a PP of -33C, but 80W is a test conducted at -26C.
My gear lube won't pass 75W, but I'll bet the channel point is very close to the pour point and OK for use down to -33C.
How does that cross over to engine oil? Down to the PP, the oil should flow into the pump.
Back in the day before W grade tests were established, the PP was the benchmark for cold temperature performance.
Yup, exactly, that's why specific tests (CCS and MRV) were developed.Definitely. But some engine failures in the 80s showed that it was unreliable. Even though the oil should have been pumpable it was not because when placed under shear at the pump inlet it would cause cavitation, as noted above.
And gearcase applications are different than for pumped engine oil.
Using a 10w30 in a 5w20!!!!! Oh the humanity by some. My car spec's a 0w20 and run a 0 or 5w30 and have had great results. Thanks Ken!For a multi grade you look at the MRV and CCS data. That kv40 10cSt ∆ is significant - that's 100 deg F
Where an API designated product, If VM are employed, Mfg must label the product as a 10W or 5W if it meets fits below the upper spec margin for that winter rating
I am running a 10W30 in a 5W20 spec engine with better than factory results; it has a pour point of -54 degC.
Quaker State Full Synthetic - If you are thinking of a "more robust oil" I would recommend this product highly.
- Ken
Other than in a gear application where channel point is important, I wouldn't subtitute knowing the PP for the W grade.Yup, exactly, that's why specific tests (CCS and MRV) were developed.
I think the PP is good to know yes, I typically err on the side of caution with the Winter rating for a similar reason as you. As we know, an oil is allowed to slip a Winter rating in service, and that does open the door for problems!Other than in a gear application where channel point is important, I wouldn't subtitute knowing the PP for the W grade.
To be safe, I like to be at least a grade below expected ambient. I've noted zero oil pressure with 5Wxx when company trucks were parked overnight in Hinton, Alberta at or around -35C. Some guys left their Diesel engines running all night in the hotel parking lot.
At those temperatures, it's not just the trucks and other machinery that has trouble getting going in the morning.... it's me.
Notice how MRV is always a grade or two below CCS? The theory is if it will start, the oil better pump.
Well, the 2017 GMC 6.0L started, but should have had 0Wxx instead of a fast lube place syn blend 5w30.
Because MRV is an indication on how the oil will flow under its own weight due to gravity, and be able to flow to the oil pump pick-up. The oil's ability to flow to the pump pick-up is the critical aspect of a super cold start-up. If it can't flow to the pump pick-up, it doesn't matter how well the pump can move it. No oil supply to the pump pick-up means no lubrication going to the oiling system. Boom, smoked motor.Notice how MRV is always a grade or two below CCS? The theory is if it will start, the oil better pump.
When my daughter was in undergraduate school in northern Wisconsin there are times when she started my/her old 1994 BMW 530 in -30F temperatures. You are correct that there are can be all sorts of protest noises from the engine at those temperatures. It’s not for the faint at heart especially with a ~25 year-old car. I always told her to let it warm up before proceeding and to make the trip count.I think the PP is good to know yes, I typically err on the side of caution with the Winter rating for a similar reason as you. As we know, an oil is allowed to slip a Winter rating in service, and that does open the door for problems!
I've recounted this story before, but when we were driving back from my parent's place down east we stopped overnight in Quebec. It went below -30C that night and in the AM I didn't think the Expedition was going to start (the diesel beside us didn't start, they had to bring a big trailer in to get it going, not sure of everything they did, I assume block heater + boost). It was an honest -30C, no wind, I had Pennzoil Ultra 5w30 in the sump instead of my usual Mobil 1 0w30 and it rolled over so slowly I was sure it wasn't going to go. It did eventually catch and made all kinds of exciting noises for an uncomfortable amount of time. That was the last time that truck saw a 5w30.
This is part of the reason I'm big into the PAO-based 0w-xx lubes in my own vehicles. Our RAM fired-off without even a hint of rolling over slowly when it was -30C this past winter with the EP 0w-20 in it, same with the SRT with the Ravenol. It makes a difference.
