CHP/ Combine Heat Power Unite
illinois, usa
Overkill had a great post regarding large power generation. If you happen to miss it, here is the title
PowerGen pros and cons - an honest discussion​
In a smaller scale for a home owner, small town or even a manufacturing facility can used a CHP unite. Think of it this way, for home owners an appliance the size of a refrigerator that runs on any fuel and produces electricity like a generator but uses the heat to provide hot water for showers or for heating the house.
The CHP is smart enough to transfer any excess energy/ power into the grid or to a battery bank system.
My building during grad school ran on a CHP unit with a solid oxide fuel cell running off natural gas. Seemed to work really well in that application though it was way larger than what you'd need for a standard (or even large) home.
There is no reason that the size can not be adjusted to the needs, the article that I read was a home owner running one in the country side/ England.
Will this be cheaper than HVAC based heating? Also the noise level of a 4 stroke engine may be a bit much for a residential unit. For large scale system a fuel cell based unit may help reduce peak electricity use in the grid but unless it is used as an absorption based cooling + cogeneration it won't be the best IMO.
The system can actually be place outside the house or in a garage location.
It would be too expensive and takes a lot of space for doing partial workload. Expensive system like this typically need all day operation to justify, which is why CHP are mostly industrial scale so far.
