Ontario's Green Energy Boondoggle - Continued
OVERKILL
$100 Site Donor 2021
Ontario, Canada
Similar to what Shannow has seen unfold in Australia, Ontario had a government-forced Green Energy Act foisted upon the ratepayers. Officially coming into effect in December of 2009, the stage was set for it in January 2005 when generation costs were decoupled from rates and the Global Adjustment was spawned to cover the rate subsidies that would be provided as incentives to private contract holders for the installation of wind, solar and biomass.
In 2002, before tiered pricing was introduced and came into effect sometime in 2003, retail rates were $0.043/kWh. Generation mix was pretty basic with nuclear, coal, hydro and gas/oil/coal making up the mix. Demand in the province would have been around 152TWh, which means total retail cost to consumers was $6.5 billion dollars ($8.6 billion in 2017 dollars).
Rates went up modestly, with some variance, between 2004 and 2010 with tiered going from 5.8/6.7 and TOU from 3.5/7.5/10.5 in 2006 to 6.4/7.4 and 5.1/8.1/9.9 in November 2010.
Then things went sideways.
Between 2010 and present tiered has jumped to 10.3/12.1 and TOU to 8.7/13.2/18. Generation costs are the primary driver as Ontario struggles to deal with a precipitous drop in demand, going from 152TWh in 2007 to 137TWh in 2015 whilst continuing to dole out contracts for more intermittent generation with curtailment compensation clauses and rate subsidies. The increased costs, passed on to consumers, continued to push down demand, which in turn reduced the size of the pool from which the compensation for the subsidies was drawn, further driving up rates. This is evidenced via a comparison of rates relative to demand following 2010 through to 2015.
What is not seen through the lens of a rate focused approach are the infrastructure costs also passed on to consumers. This is represented by the Delivery Charge on our bills, and mostly affects HydroONE customers, as they are the largest provider in the province and serve the vast majority of rural consumers. Since most of the large scale renewable installs are outside city limits, their connection to the grid is tasked to HydroONE, who then receives approval from the Ontario Energy Board to recoup those costs from their customers via Delivery and Regulatory charges.
This brings us to what 2016 looked like. Note that generation breaks into two main categories:
Grid-Connected: These are resources, usually large scale, that participate in the IESO regulated energy market. These are reflected in the IESO generated distribution mix data. This is what I've focused on in past discussions.
Embedded: These are smaller scale installs connected and administered via local Utility companies, I have not mentioned these before. They operate at a local level to drive down grid demand. The IESO does not provide annual output data that I could find for these installs, so I have based it on the average large-scale data, which is readily available.
124TWh generated via grid-connected nuclear and hydro with a total cost of $8.28 Billion, which breaks down as:
Bruce Nuclear: $3.15 Billion
OPG Nuclear: $2.98 Billion
OPG Hydro: $2.14 Billon
23TWh generated via grid-connected gas, wind, solar and biofuel with a total cost of $3.59 Billion, which breaks down as:
Gas: $2.07 Billion
Wind: $1.24 Billion
Solar: $218 million
Bio: $63 Million
5.1TWh generated via embedded biofuel, gas, CHP, wind, solar and hydro with a total cost of $1.6 Billion, which breaks down as:
Solar: $1.34 Billion
Wind: $184 Million
Hydro: $58 Million
Bio: $14 Million
This gives us a total generating cost of $13.47 billion, of which $3.1 billion is wind, solar and biofuel, which account for less than 10% of the generating mix.
How this has unfolded would be novel had it not had the result of putting many residents of the province into energy poverty. Essentially, the goal was to replace two coal plants the province was operating with wind and solar. To incentivize investors, lucrative contracts were drafted with generous rate subsidies, compensation for non-generation and the like. In order to try and match the 30GWh the coal facilities provided, a significant amount of over-capacity was deemed necessary. On top of that, contracted Natural Gas generation would be added to prop-up the renewables for periods when they were not producing. These facilities were given similar contracts, being paid to idle.
The subsidies were recouped via an increase to consumer rates. This in turn drove down demand. This did not however cause the government to re-evaluate the contracts that had not yet begun construction. The government continued to allow new builds, which in turn further increased cost, which again drove down demand. This resulted in periods of significant surplus. As local embedded generation, which was also being subsidized, drove down grid demand even further, the surplus increased. Often these private facilities were generating when the power was not needed, which resulted in the province selling the power off at an average of 20% of what the Ontario rate payers paid the contract holder, or paying the facility for curtailment. Other times, they were not producing and expensive dispatchable gas generation was leaned on, again, at significant cost to the rate payer. In 2016, excess generation sold at a loss cost Ontarians $1.7 billion dollars.
But it gets even better. HydroONE has now announced that it needs more money to fund grid maintenance, as it has been neglected due to that money being funnelled into renewable connection infrastructure. This is at the heels of the Premier justifying all the extravagant expenditure which amounts to $50 billion as "upgrading the grid", stating that previous administrations had been neglecting it. That is quite obviously a lie.
This has all been an extensive exercise in how not to integrate renewables into your grid. This is because the entire plan revolved around agenda, not properly vetted policy and sound economics. There were plenty of ways that this could have been done properly, unfortunately those in charge had no intention of following any of those methods and instead charged ahead with a system that was destined to fail. This was due to an approach that did not properly evaluate the cumulative effect that the subsidies would have on consumer rates, or factor in the effect on demand that an increase in rates would have. Additionally, it did not factor in the relationship between those two items.
Where we go from here? That's to be seen. There are a variety of options being explored by the opposition, none of which are popular with the current administration because of various "cozy" relationships with contract holders. Alternative administrations have no such obligations to those parties, so it will be something to watch in the next year and a bit.
Originally Posted By: SHOZ
In the mean time in the US wind is driving electric cost down.
The wind installation built south of Cape Cod is AWASH in subsidies. Back up your claim. The only thing lowering costs in Southern New England is cheap natural gas.
Not to take away from the thrust of your argument (and the Ont. government has run a poor policy in regards to integrating renewables), however the lack of investment in grid infrastructure by previous provincial governments is quite accurate. The costs of new nuclear construction ballooned in the late 1980s and into the '90s, and the Conservative and NDP governments of the day were also battered by accusations of mismanagement due to rate increases as those costs had to be paid for. Those governments froze rates to save their own hides to the detriment of future generations. The previous governments (all three parties, mind you) froze rates and diverted spending on the grid (especially the Harris government in the '90s). Fast forward and here we are.
By the early 2000s, you might recall brown outs and black outs during the summers. There had been little or no investment on new capacity or simple maintenance, period. Following McGuinty's election, spending increased as the Ministry of Energy realized the show was going to stop eventually. Our problem is that voters don't like people who tell the truth about what it costs to operate mid-twentieth century electrical grids on the cheap until things start falling apart. And now that $12 Billion from the nuclear construction and the other billions in upgrades are being paid off. The renewable policy hasn't worked out as well as they hoped for sure (apart from getting rid of the coal burners, that helps everyone-if only the U.S. border states would do the same and our air quality would be improved even more and we would see the end of smog days).
Considering we sell electricity to the U.S. at a loss and we generate more than we require, it does seem illogical that costs have increased so much. Yet there is a history of poor governance here that cannot be ignored, by all three parties. Now, the promises to reduce rates mean those costs will just be borne through the use of taxpayer dollars found elsewhere. Is the green energy act a flawed document and policy? Sure it is; but a lot of those rate rises over the years are because voters don't like truly honest politicians who can make tough choices and defend them, so we don't hear the reality that things cost money. Instead we get comforting lies.
As Energy Mix Becomes Cleaner, Minnesotans Paying Less for It
Quote:
Consumers have seen flat or declining energy costs as renewable energy becomes a greater part of the energy mix of Minnesota and the nation.
That’s one of the findings in the annual 2017 Sustainable Energy in America Factbook, published by Bloomberg New Energy Finance in partnership with the Business Council for Sustainable Energy.
The report points out that in the U.S., renewable energy, greater energy efficiency and low natural gas and gasoline prices have combined to drive down energy costs — as a percent of total household spending — to its lowest level in decades, according to business council president Lisa Jacobson.
Energy spending in 2016 represented 3.9 percent of household expenditures, the first time the figure dropped below 4 percent ever, based on data from the Bureau of Economic Analysis, she said.
The bureau began reporting on energy in 1959. “Consumers have never paid less of their household family income for energy, ever, on record,” Jacobson said. “It’s amazing.”
Actually, no.
The city I live in does "aggregation" on our behalf and we have to opt-out if we don't want the chosen electric provider. Last go-round they chose a company that provided electricity that was "clean" and wind-generated. The negotiated rate was higher than the "dirty" energy but the city went with it anyway, and since it was negotiated on a bulk purchase, it was cheaper than had I chosen them myself -- but it was still more expensive than the rest of the options they reviewed. After a year, they gave up.
So, at least in my little slice of heaven, wind didn't drive any costs down. YMMV
Its easy to take one report out of context.
The report cited by Shoz states that electricity prices has gone down - if inflation is taken into account. Not sure if Overkill's analysis did or did not. Can't compare apples to oranges...
On top of that, the report really states that energy costs are the lowest they have ever been as a percent of total household spending - not that they are lower overall. Note that isn't just electricity - that is all energy sources, such as gasoline and natural gas - where we've benefited from the fracking boom - not renewables.
Quote:
Wind didn't drive any costs down.
Nor here, the largest wind producer in the US.
In the US a certain agency attempted, via administrative law, to completely control generation, distribution, transmission, and consumption of power.
Hopefully this overreach has been halted.
Can you give me a break-down of where there was insufficient investment?
Here's a Financial Post article describing what is transpiring at HydroONE:
http://business.financialpost.com/fp-com...s-soaring-rates
Give it a read.
- Pickering A came online in 1973, B online in 1986
- Darlington came online between 90 and 93, however construction was started in 1981. The total bill for Darlington was $14.4 billion.
- Bruce Nuclear came online in phases between 1970 and 1987. Cost was $7.8 billion.
So the only one coming online in the late 80's/early 90's was Darlington really, and the only one that was expensive. There was no reason for Darlington to cost almost double what the 8-unit facility at Bruce cost.
And any rate increase we've seen since then has absolutely paled in comparison to what has happened in the last 17 years.
The grid was relatively static however. It was all existing infrastructure, so even if costs were being deferred, it is nothing like what has transpired since the GEA.
No, I never experienced that, either here, or in Muskoka actually. The only time we had black outs was when a pole went down during a storm.
The debt associated with Ontario Hydro totalled $30.5 billion ($38.1 including liabilities) in 1999, and left $20.4 billion in stranded debt not attributable to the new entities. This resulted in the subsequent spawning of the DRC, which added $0.07/kWh to bills with the intent of paying off that stranded debt, but this was recently killed by the Liberals for residential customers and the stranded debt hasn't been paid off by them either, and the spinning off of HydroONE leaves less money to pay it off with.
Despite the already significant debt figure, and maintenance that needed to be done, the government instead embarked upon this massive expansion exercise with wind and solar, further kicking the can down the road on maintenance as per Hydro ONE's claim.
That's being modest, it has been an utter disaster. Coal was replaced by Natural gas, which still results in CO2 emissions. Instead of the government bearing the cost of the generation expansion projects through public institutions like OPG, the Liberals doled out contracts like they were carnival tickets, resulting in massive over capacity and sky high consumer rates to cover the subsidies. Since the rates were guaranteed, all the excess is sold at a guaranteed loss, furthering the disaster.
We sell it at more than a loss, we sell it at a massive loss, we lose 10 cents per kWh on the energy we sell to the States due to the rate subsidies. Yes, there is a history of incompetence and passing the buck to placate consumers, however the GEA burdens those costs directly on the consumers for for-profit enterprise, which is why those modes are paid massively more than the existing infrastructure that makes up 85% of our generating mix and gets paid less than $0.07/kWh.
Essentially, we are dealing with two issues here:
1. Rising rates, which deal with direct costs through OPG and HydroONE, as well as 3rd party costs via rate contracts paid to private generators.
2. Delivery charges, which deal with infrastructure costs, which, as HydroONE has stated, have primarily been spent on connecting new, private, generation to the grid, rather than dealing with actual grid maintenance, which they indicate is a looming expense and requires addressing.
Consider this: OPG is paid $0.059/kWh for their nuclear generation, and then there are additional charges tacked onto that rate to cover debt and the like, which drives their cost up to $0.068/kWh. The originally planned expansion of Darlington with a sticker price of $12 billion on a 30 year note would amount to ~$0.089/kWh for that pair, which is significantly less than what we are paying the wind, solar and gas plants, and none of the rates we are paying them covers infrastructure either, that's through HydroONE.
The current promise to reduce rates by Wynne is nothing more than a sham that will cost us billions more by amortizing the cost of 20 year contracts over 30 year periods. It makes the situation worse, and provides no real relief.
What needs to be done is the scrapping of the rate contracts or renegotiation with greatly reduced rates and excess generation to be sold at market with no cost to consumers. This will have an immediate effect on generation charges through the global adjustment and will actively drive down prices significantly, while still allowing existing generators through OPG and Bruce to be paid reasonably to cover the refurbishments currently in process or in queue. I don't think Bruce and OPG, which average less than 7 cents per kWh, are unreasonably priced. I do however think that paying $0.42/kWh to my local solar farm is insane, considering it has none of the liabilities of Bruce and is expected to be intermittent/unreliable.
The energy system in the province has costs, I think we can agree on that. Some of those costs have been deferred by previous governments trying to keep voters happy, and that has resulted in debt. However, thanks to the disastrous policies of the present and previous administrations, we have ballooning rates that do nothing to deal with that existing debt and instead are giving money hand-over-fist to private contract holders who have no responsibility to rate payers for connecting their generation to the grid. This is what I have a serious issue with.
In conjunction with that, HydroONE is passing on the cost of connecting all that disparate generation to the grid via a delivery charge, which is particularly hard on rural ratepayers, making it a double whammy for those living outside urban centres. That is money that could have been spent on actually maintaining and upgrading existing grid infrastructure had we gone an alternative route of replacing the coal plants with something a little more sensible and less distributed.
Originally Posted By: Dan55
So whats your cost per KWH including delivery charges?
It varies per person depending on how much of your usage falls within the three rate categories as well as how rural you are. I think the last time I averaged mine I was around $0.128/kWh for electricity without delivery. My delivery charge is usually in the mid to high $30's a month, so if I used 750kWh and had a $38 delivery charge, I'm paying $0.051/kWh in delivery, making my overall rate $0.179/kWh.
However, my buddy who lives in the country, let's say he averages $0.135/kWh for electricity and uses 650kWh. His delivery charge is $96.00, which is $0.148/kWh. That means his overall rate ends up being $0.283/kWh. Someone even more rural will pay more.
Make sense?
Just on general principle, I think the renegociating the contracts for renewables is the best way forward. These are, in essence, subsidies for the producers which cannot continue ad infinitum. I'm not adverse to buying hydro from Quebec at market rates, either. At the same time, I also believe there is plenty of blame to go around, right back to the Harris gov't.
We need to have competitive electricity rates, for both consumers and industry, but especially for industry...
Originally Posted By: SatinSilver
Hi OVERKILL,
So much does your bill run each month approximately if you don't mind me asking?
I would bet less than the family cell phone bill.
Similar happened with Austin's city-owned electric utility...that's 'directed' by their silly/city council, meaning it's subject to their green/utopian true believers that "anything is possible". There were actually brainwashed customers who believed the electrons flowing into THEIR house were only from renewable sources rather than coal/gas/nuclear, just because they had signed up to pay EXTRA for it!!
That's the level of stupidity of those who made these decisions in the mid-90s.
Green dream indeed...boondoggle. They ranted & raved when 'their' rates shot out of sight. The 'energy bin' system set up by the silly council turned into a black hole and needed to be bailed out. Result? The silly council implemented a 'tiered-rate' schedule for the first time and raised everyones rates.
My max monthly usage here during the Summer is about 1300kWhrs, so I'm a low-user. However, my rates shot up ~ 18% to bail out their fiasco.
All this while the price of NG sank to an all time low. Other non-monopoly utility customers were seeing their rates DROP at the time of this INCREASE.
Boondoggle indeed......
Hi OVERKILL,
Through conservation, I've managed to get my usage down to just over 600kWh a month now, so I pay ~$200.00. I was well over $300.00 before buying a new high efficiency fridge and induction range.
However, I'm in town, so my delivery charge is much lower than somebody who lives out of town. Also, my bill includes water and sewer (they are around $32/each).
My buddy in Warsaw, he pays about the same as what I pay, except he's not getting water and sewer, his is straight electricity and delivery, and he's living in a 4 year old high efficiency home heated with propane. If you heat with electricity the bill is absolutely insane.
I'll give you an example:
There's a restaurant that operates out of an old house outside of town. Nice fine dining establishment. They are shutting down, citing hydro costs as a big component. Their bills went from $2,500-3K a month to $7,000 a month, that's an increase of 40-50,000 dollars a year, just in electricity!
For facilities running large fridges or any sort of high electricity usage appliance, the electricity costs have become a huge issue. For rural home owners that heat with electricity, some of them have been caught by this rapid uptick and are unable to heat via other means. These would be people with electric baseboard that can't just swap over to forced air without incurring massive expense. There was a local woman who was crying to the Prime Minister when he did his cross country rockstar tour, saying her hydro costs more than her mortgage, so you can safely assume she's paying at least $1,000 a month for electricity for her home.
I think we are generally in agreement here.
Hi OVERKILL,
Cell phone plan (with my wife on it) is $180/month, and I get half of that back through work, so actually no.
