OVERKILL
$100 Site Donor 2021
Just saw this Reuters article:
pint-sized Nuclear plants
Which gave me a bit of a chuckle, as I was recently thinking about the feasibility of a pressure-cooker sized CANDU due to the obscene power prices in Ontario.
The article got me thinking about the issues regarding current sites in large countries like the US and Canada where often we are running transmission lines obscene distances due to the location of the facilities. Local generation options are often limited by geography (we have 5x hydro electric dams but of course that's not an option everywhere) and sometimes importing power from elsewhere is the only real option for base-load.
These "mini nukes" could be, as the article details, transported in parts via rail or truck, and would be modular and standardized. This drives down the cost and of course this, in conjunction with their size, drives down the time to the site going live. Coupled with a distributed fuel reprocessing model, breeders, or some distributed flex-fuel CANDU's and you could have distributed generation with very little total waste and a great amount of generation, which would be good for the price of electricity relative to the electrification of the automotive world and for driving electric transit and the like.
Regarding the size, our local solar field is 200 acres and has a nameplate capacity of 10MW. 50MW in something the size of a school bus is absolutely incredible in comparison. At $5,230,000 per MW (based on the 440MW example above) it actually compares quite favourably, as the solar field cost us $4,500,000 per MW in comparison and the uptime of the nuke is several times higher than the solar field. Per KWh per year, the nuke would wind by a landslide, you get far, FAR more for your dollar.
And this covers a lot of what we have discussed on here regarding intermittency and baseload.
Originally Posted By: Reuters
A range of mini-nuclear power plants could help solve Britain's looming power crunch, rather than the $24 billion Hinkley project snarled up in delays, companies developing the technology say.
So-called small modular reactors (SMRs) use existing or new nuclear technology scaled down to a fraction of the size of larger plants and would be able to produce around a tenth of the electricity created by large-scale projects, such as Hinkley.
The mini plants, still under development, would be made in factories, with parts small enough to be transported on trucks and barges to sites where they could be assembled in around six to 12 months, up to a tenth of the time it takes to build some larger plants.
"The real promise of SMRs is their modularisation. You can assemble them in a factory with an explicable design meaning consistent standards and predicable costs and delivery timescale," said Anurag Gupta, director and global lead for power infrastructure at consultancy KPMG.
In a nuclear power plant, heat is created when uranium atoms split. Different reactor designs use this heat in different ways to raise the temperature of water and create steam, which then powers turbines to produce electricity.
Manufacturing advancements mean SMR developers are only a few years from being able to replicate this technology on a smaller scale, and plants could be ready for deployment by the mid-2020s.
"From a technical perspective there is no reason why you wouldn't be able to make a smaller version of an already commercially viable nuclear technology such as PWR (pressurised water reactor)," Mike Tynan, director of Britain's Nuclear Advanced Manufacturing Research Centre (NAMRC), said.
There are already more than 100 nuclear plants using PWR technology in operation across the globe.
NuScale, majority owned by U.S. Fluor Corp, is developing 50 megawatt (MW) SMRs using PWRs which could be deployed at a site hosting up to 12 units generating a total of 600 MW. The 50 MW units would be 65 feet (20 metres) tall, roughly the length of two busses, and nine feet in diameter.
Rolls-Royce, which already makes components for PWR nuclear submarines, is part of a consortium developing a 220 MW SMR unit which could be doubled for a larger-scale project.
Rolls-Royce Chief Scientific Officer Paul Stein said the first 440 MW power plant would cost around 1.75 billion pounds ($2.3 billion) but costs would likely fall once production is ramped up.
"One of the advantages of the SMRs is that they cost a lot less (than large nuclear plants), and it is an easier case to present to private investors," Stein said.
Critics, however, say there is no guarantee that SMR developers will be able to cut costs enough to make the plants viable.
"SMR vendors say factory production will save a lot of money, but it will take a long time and a lot of units to achieve what they are calling economies of mass production," said Edwin Lyman, nuclear expert at the U.S.-based Union of Concerned Scientists (UCS).
"Factory manufacture is not a panacea. Just because you are manufacturing in a factory, it doesn't mean you are certain to solve problems of cost overruns," he said.
Costs are a sensitive issue and could have played a part in Britain's decision to review the $24 billion project to build the two new Hinkley Point nuclear reactors led by French utility EDF and Chinese partner China General Nuclear.
Almost half of Britain's electricity capacity is expected to close by 2030, as older, large nuclear plants come to the end of their operational lives and coal plants shut as part of the country's efforts to meet its climate goals.
The two new reactors at Hinkley Point are supposed to provide around 7 percent of Britain's electricity, helping to fill that supply gap. Nuclear developers are confident SMRs could be up and running by the late 2020s, in time to help bridge the looming electricity supply shortfall.
A study carried out by the National Nuclear Laboratory, a government owned and operated advisory body, said Britain could host up to 7 gigawatts (GW) of SMR capacity by 2035, more than double the capacity of Hinkley.
But anti-nuclear green groups such as Greenpeace argue that with advances in renewable technology, such as offshore wind, Britain may not need any new nuclear plants.
This week Britain approved Dong Energy's plans to expand an offshore wind farm project that could ultimately span an area of the North Sea more than twice the size of London and produce up to 4 GW of electricity, more than Hinkley Point.
Nuclear power defenders say the intermittent nature of renewable electricity production and lack of grid-scale storage mean nuclear plants are needed to ensure continuous supply of power if the country is to meet its emission reduction targets.
"Working alongside renewables, nuclear provides the reliable low carbon energy required to balance variable wind and solar generation," said Tom Greatrex, chief executive of the Nuclear Industry Association.
