Full diet of Pennzoil Platinum and sleep easy!!! As others mentioned, 5000 mile oil changes. Carry on!!!
Thanks, this is good info. Not sure about some of the other snarky responses, just here to talk oil. What about a diesel specific oil, considering the direct injection engine perhaps?GDI engines produce a fine soot that gets into the engine oil. That soot in turn increases the chance for timing chain wear.
The new SP/GF6 oils address this.
Unless someone can honestly show that a diesel specific oil would work better than what the owner's manual says, I would stick to what the OM says. Gone are the day when motor oil was much more simple and they were all about dual rated for gas and diesel engines.Thanks, this is good info. Not sure about some of the other snarky responses, just here to talk oil. What about a diesel specific oil, considering the direct injection engine perhaps?
Very good advice. Auto mfg. Companies have engineering departments who make specific recommendations concerning maintenance requirements for our cars. I have to believe that these recommendations and requirements are based on sound data and analysis. Why anyone would second guess that, based mostly on a hunch, tip, or granddaddy did it this way ,is beyond me.Unless someone can honestly show that a diesel specific oil would work better than what the owner's manual says, I would stick to what the OM says. Gone are the day when motor oil was much more simple and they were all about dual rated for gas and diesel engines.
Castrol Edge 5w30. 7.5 k oci.
How do these oils address the problem? What additives, base stocks, or, perhaps, viscosities, prevent or minimize chain wear? If you're changing oil frequently, does using the newer oils really matter that much? You're suggesting that "fine soot" gets into the oil, so wouldn't more frequent changes be beneficial, perhaps more so than going the distance with an SP oil?GDI engines produce a fine soot that gets into the engine oil. That soot in turn increases the chance for timing chain wear.
If you plan on putting 300K on it, I don't recommend following the OLM if it allows you 10K oil changes.
The timing chain system is todays wear point in a modern engine. It was addressed in the current Dexos spec, but
I bet there will more timing chain stretch at 220K with 8-10K OCI's vs someone who did 5K OCI's.
I second this recommendation. I love my Castrol stuff. But any name brand oil will be fine.Magnatec
Any Dexos oil including Super Tech, change when OLM says too.This truck isnt driven very much, so 5k mile OCI's is the plan. plus, they are easy to keep track of!
You're heading in the right direction in my opinion. All the 15W40s would be considered "high mileage" engine oils, weather permitting.I've been alternating between M1 and Pennzoil Platinum 5w30 since it was brand new. At around 45,000 miles, I noticed the start of consumption, so I've bumped it up to Castrol Edge 5W-40. Consumption hasn't really slowed. I'm considering moving to a 10W-40 High Mileage oil, in case it's valve seals, since nobody seems to make a HM 5W-40.
Not sure what caused this, as the truck has lived a very pampered life, but keep an eye on your oil level, and keep it changed every 5,000. The 3.6 has a sensitive timing chain.
I wouldn't really say that 7.5 is an extended oci. I'm sure the recommended Dexos 5w30 SP, gf-6 will hold up just fine.I'm generally a proponent of extended OCIs, but this is one engine that you cannot do that with. Otherwise you'll end up replacing the whole timing system right when its out of warranty.
