Originally Posted By: DragRace
Originally Posted By: turtlevette
Do you guys think oil pressure is instantaneous? Is the last thing on the oiling loop going to see pressure within 1ms of startup. I think not.
Every time you start, something in the engine goes without pressure for a fraction of a second to multiple seconds depending on the viscosity.
*Fact*
It's really too bad more people dont have the opportunity to take some auto mechanics classes.
Alot of assumptions and guessing would'n't be happening so often on this forum.
Just because you don't have oil pressure for a second or two on a cold start doesn't mean the parts aren't still being lubricated and protected.
Even when I change oil and filter, and the whole oil gallery system has drained out, and the filter is bone dry, the oil pressure light goes off within 2 seconds. On cold starts after the engine has ran after an initial oil change, the oil light goes off while cranking even before the engine fires up.
*Fact*
