I've been going 10k miles on Mobil 1 and OEM oil filter changes since the early 1980's. Until recently, I never had a car that burned any oil between changes and the top end of the engines have always looked super clean. My latest vehicle, a 2011 Acura TSX wagon purchased new, started consuming oil at the rate of about 1qt per 4,000 miles three years ago at around 65k miles. That increased to 1qt per 2,500 miles the following year. Then I got a notice from Acura about low tension oil control rings sticking from combustion deposits along with an extension of the warranty which just expired. At that point I started adding Techron every few thousand miles and switched to top tier gas. Oil consumption has slowly dropped to 1qt per 6,000 miles. I still have to add a half quart a couple of times between oil changes and am hoping that holds or improves. I am now thinking of switching to 7,500 miles for oil and 15,000 miles for the filter. Still using M1 0w20, but might switch to high mileage at this point. For a filter, I'm looking at Fram Ultra Synthetic because it seems more robust than the OEM Acura filter. Never thought much about filters until now, but I've never gone 15k miles with one before. I'm mainly worried about the high concentration of detergents in the fuel when I add the Techron two or three times between oil changes and the chance of fuel and detergents washing down into the oil. Some people only add Techron before an oil change because of this.
