- Joined
- Sep 26, 2010
- Messages
- 9,837
Originally Posted By: BlueOvalFitter
Originally Posted By: 2010_FX4
IMHO - if you extend your OCI long enough, you will only need to use the filter once as it will used up and should be replaced.
2010_FX4, what OCI do you think I should run the Havoline in my engine to?
Based upon your highway miles, I would start with the maximum recommended OCI by the OEM and extend from there until you hit the limit (test with UOA to know for sure). I know that MS5K will go 10K as will the MC FL-820s on my FX4 so you should at least be able to go to 7.5K as a start with the Havoline. Right?
