Filter change intervals
Originally Posted By: LScowboy
Pennzoil, Mobil, Castrol, Quaker State, Valvoline, etc. are filtered to a crazy degree, my bottled spring water I am drinking right now likely has more particulate than these high line oils, and used motor oil does by many times over. In fact, it is particulate that is responsible for most of the opacity and dark color of used oil. Black carbon is a particulate!
Do some more reading before making strong claims backed up with no data/info. You're new here; BITOG has a wealth of info - take the time to read through some of it.
would you pour in a quart of nasty used oil in with your 4 qts. of clean oil when you do an oil change, because that's what you are doing!
No way a filter holds 1 full qt. of oil. No way.
actually, some filters hold MORE than a quart of oil, I recently posted pics of one that holds 40 oz. (although most hold more like a pint or even less, but you get the point)
THATS the point.
Originally Posted By: BlueOvalFitter
And, after seeing the UOA 2010_FX4 has done on his F150 with a MC oil filter I feel safe up to 7.5K OCIs with my MC filter and conventional 5W30 oil.
If you're going 7,500 miles with a MC filter, I would absolutely change that at every oil change.
7,500 miles on one filter is, as you know of course, the same as using the same filter on two 3,750 mile runs. It's the miles that count.
Glad to see that you're going to start using the filter for closer to its expected life.
Thank You Sir. Common sense prevails.
What a minute BOF ... now you're agreeing that 2 x 3,750 OCIs is OK now?
NEVER. I was agreeing to use my MC oil filter to 7500 miles, AKA, one time!
Guess when he said "as you know of course", he was mistaken.
Guess when he said " as you know of course", he was mistaken.
I just can't use an oil filter twice, being they are so cheap.
I read all of the links you provided, quite short on quantifiable science, mostly just us BiTOG blowhards theorizing! - nothing to convince this engineer whatsoever - just because someone got a used oil analysis or VOA back with some interesting weird data is proof of nothing, many of these labs need a calibration, badly! - no controlled studies of any kind, a judge would throw all of this "evidence" out! (think in your own mind, does this *really* seem logical? - REALLY?)
and I am actually not new here, I joined in late 2002, lost that user ID when I changed ISP's and no longer could access email for password retrieval, youngster!
LS - I do apologize.
The UOA evidence was not conclusive, but a trend was seen with more wear per mile at the start or during shorter OCIs and that stuck in my mind.
Now the fresh oil contamination - that I have heard thrown around a few times and there did seem to be legitimate findings that sometimes your bottle of oil has particulates already in it!
I still feel that leaving a decent+ quality filter on for 2x OCIs should be of no concern.
1) You can't get all of the old oil out anyways (filter or no)
2) It has been proven that wear is higher with fresh oil following a change vs later in the OCI
3) Most filters hold 6oz or less if the sump is 5qts or smaller
4) New oil can have contaminants and that 'used' stuff in your filter may actually be cleaner, particulate-wise
5) It saves money, resources, landfill space, ...
6) Engines do not shed metals like they used to - filters do not 'get plugged' during normal OCIs
Actually surfstar is right, more or less, he just used so-so references. Some of the better references were contained within the references he made but someone would have to actually read thru the material to glean it... something people with closed minds usually don't take the trouble to do if the facts don't support their opinion. "Plausible deniability" I guess.
FIrst, RE: lower wear with old oil, I would point to a great study done by Ford and Conoco in 2007 which showed that aged oil, with more than 3000 miles on it actually showed less friction and wear than new oil and that the oil actually got better with age in this regard. You can read about it in SAE paper 2007-01-4133 "The Effect of Drain Interval on Valvetrain Friction and Wear." This was done in a collaboration between engineers at FoMoCo and Conoco (who designs and blends the Motorcraft oils). The paper is available at SAE.org ( HERE )
The abstract says:
"Abstract:
Engine oils are subjected to a series of industry standard engine dynamometer tests to measure their wear protection capability, sludge and varnish formation tendencies, and fuel efficiency among several other performance attributes before they are approved for use in customer engines. However, these performance attributes are measured at the end of tests and therefore, do not provide any information on how the properties have changed during the tests. In one of our previous studies it was observed that engine oil samples collected from fleet vehicles after 12,000 mile drain interval showed 10-15 % lower friction and more importantly, an order of magnitude lower wear rate than those of fresh oils. It was also observed that the composition of the tribochemical films formed was quite different on the surface tested with the drain oils from those formed with fresh oils. The objective of this investigation is to demonstrate how the friction and wear performance changed with oil drain intervals. A fleet of three vehicles was run in Las Vegas and oil samples were collected at various drain intervals from 3000 miles to 15000 miles. As in the previous study, the results showed that the aged engine oils provide lower friction and much improved wear protection capability. These improvements were observed as early as the 3000 mile drain interval and continued to the 15000 mile drain interval. The composition of tribochemical films formed on the surface with the 3000 mile drain interval is similar to that formed with the 12000 mile drain interval as seen before. These findings could be an enabler for achieving longer drain interval although several other factors must to be considered."
Unfortunately, there are copyrights in effect on that paper, so if you want the full skinny, you have to pay to play, as many of us have done. It wouldn't be legal to post it. Dave Newton, dnewton3, has expounded on that study from a statistical standpoint and you can read more in the "What is Normal" stickies in the used oil analysis section and we (the BITOG we) have discussed it at length if those who are interested wish to search. The 2007 study refers to an earlier one that found similar results while they were looking for something else.
As to new oil being dirty, it is. Not enough to be a problem but sometimes, initially, oil gets cleaner with use. If you do some google searches on new oil cleanliness, you can see it's a problem in some venues.. mainly bulk oils. My main point to make is to not assume new oil is some sterile, particle free liquid. Some oils are better than others, and there are some oils on the list I have that are very clean in comparison, showing the blender takes a lot of care. But particulate wise, your new oil may require some cleaning up from the engine oil filter and there could be a very short period right after the oil and filter is installed and the oil has made a few passes thru the filter, when the oil is actually cleaner than when it was installed. Not that this really matters a hill-o-beans because, unless you are very unlucky and got some serious sludge-in-a-bottle, the "dirty" new oil is still within the safe operating threshold of the engine. But it does provide some interesting things to think about. One Noria source postulated that 17/14/13 is the optimal oil cleanliness level, but that is obviously only attainable with bypass filtration. In that regard, here is an interesting example:
A mining company went from very short 12,000 hour rebuild periods on their diesel equipment with oil running at 22/20/17 ISO codes to a predicted four-fold increase by filtering and maintaining the oil at a 17/15/13 level and the previous ISO code was achieved at 306 hours and the later was at 931 hours on the oil.
I was given access to some ISO cleanliness codes of new oil and I talked about it here HERE but couldn't release data. I can release some of it now but not the lab that gave it to me. 2010FX4 and I collaborated on some tests to compare different methods of taking particle counts and our info is there as well. My Mac does not allow me to format this stuff in a way that works in these code boxes but it's readable. Take note that some of these are pore blockage tests and some are optical counter (OP)... and there is a significant difference in those test results, the pore showing lower, by about 25%) At one point in my list, the average oil cleanliness was 20/19/17 (all on the same optical particle counting machine).
That means in one ml of NEW oil, there are:
>4um= 5-10,000 particles
>6um= 2500-5000 particles
>14um= 640-1300 particles
Note also that some new oils on this list were as dirty as some used oil I have seen PC tested.
Here are some PC tests from my own truck. Note that the 5000 mile test is not that much dirtier than the Mopar 15W40 at 23/21/16, which was showing even more particle in the >6um range than the filtered used oil.
Virgin- 20/19/16 (MC 10W30 HDEO)
5000 Miles- 24/22/16 (before bypass installation)
9830 miles- 20/18/14 (4610 miles on 5 um bypass)
Code:
Date of test Oil Brand Oil Viscosity ISO4406 Test Type Virgin or Used Notes
6/3/09 Royal Purple 15W40 18/17/15 pore used/1682 mile pre LFS
10/20/09 Royal Purple 15W40 16/16/13 pore used 2251m post LFS
12/15/11 Motorcraft Super Duty 10W30 20/19/16 OP virgin container
12/15/11 Motorcraft Super Duty 15W40 20/19/18 OP virgin container
12/15/11 Motorcraft Super Duty 15W40 19/19/18 OP virgin container
12/15/11 Mobil Super 5000 5W30 20/19/17 OP virgin container
12/15/11 Shell Rotella T T6 5W40 20/19/16 OP virgin container
12/15/11 Chevron Delo 400 15W40 19/18/17 OP virgin container
12/15/11 Mopar MaxPro 15W40 22/20/15 OP virgin container
12/15/11 Mopar MaxPro 15W40 23/21/16 OP virgin container
12/15/11 Royal Purple Max ATF ATF 16/15/13 OP virgin container
3/21/12 Pennzoil Ultra SM 5W20 22/20/16 OP virgin container
3/21/12 Mobil Super 5000 SN 5W20 20/18/14 OP virgin container
Jim, once again, thanks for your excellent input and reference data.
BOF - Jim believes that your oil should be run long enough, so that a second OCI on your filter isn't possible. Take solace in that
JA, as usual, your posts' are very informative and educational.
My IQ points are 5 digits higher now.
But, it still does not change my mind on using a new oil filter at every OCI. Maybe, just maybe, if I had a clunker with an oil leaking/burning engine, I would leave a filter on and just add oil only. But I own a very nice truck and I want to keep it that way.
I don't disrespect anyone who uses an oil filter multiple times, but in return I want the same respect.
I will now run my MC oil filter a minimum of 7.5K miles, and change it along with the oil at that interval. 3-6K mile OCIs are a waste of money and oil.
I would have said the same until recently. Now I advocate getting at least one used oil analysis to verify before continuing longer runs.
Here's why. I recently did a used oil analysis on my Jeep at only 3,500 miles. I was very surprised to find a TBN of only 1.8, complete shear out of grade and "wear numbers" double to triple what I had hoped for. So it turns out my use was much closer to severe use than I thought. And I would never have known without the used oil analysis.
I had also left the filter on during that OCI. I believe that extra half+ quart of used oil that was left in likely contributed to the surprisingly low TBN on my used oil analysis.
So at least a single used oil analysis can be a good return, just to see how your use actually plays out in oil life in your vehicle. I'll be doing more used oil analysis in the future, but will not likely be paying extra for a TBN as I already know my TBN will likely be around 2 or a bit more at 3,500 to 4,000 miles.
I had also left the filter on during that OCI. I believe that extra half+ quart of used oil that was left in only contributed to the surprisingly low TBN on my used oil analysis.
Well, I am back to 3-6K mile OCIs.
Just do 5k OCI/FCI and call it good if you are using non-synthetic.
Blue, the thing you are forgetting is context. KC's comments are base on a single UOA of blend of Castrol oils used in a shorthop situation in a 4.0L inline six. And for all we know, that one time deal was a fluke, the product of something unusual or simply a sum of all the parts... oil, engine, driving situation and filter. Without trending or at least a history of a few samples with that oil in those circumstance, who really knows. It's clear, that UOA was not stellar but KC's experience was what it was... it doesn't provide a roadmap for anyone else that doesn't operate in more or less the same situation.
I just read a post, can't remember where exactly (old post though), of someone that UOA'ed his normal interval and changed the oil but not the filter, then did it again on the second oil run and you really couldn't tell the used oil analysis apart. That would be the way to test this.
Exactly!
That's why I recommend he get at least one UOA. If everything looks good, he probably wouldn't need another one as long as he didn't plan extending further or deviating from time proven, name brand oils.
And I have another UOA planned for my current fill as well, I do want to know more than you can get from a single UOA. Maybe it was a fluke, or hopefully the adjustments I've made since then will make for more pleasing results.
Blue, just run it to 5 or 6k and get a used oil analysis. If the oil still looks good you won't likely need another one and your 7.5k interval goal will be doable. That's all you need to know.
that's ridiculous
that's beyond ridiculous,
There is data that prove both.
Is science 'ridiculous'?
https://bobistheoilguy.com/forums/posts/2087109/
https://bobistheoilguy.com/forums/threads/pictures-of-whats-in-new-oil.8308/
https://bobistheoilguy.com/forums/threads/new-mobil-1r-particle-count-results.67197/
It is to most Americans.
that's ridiculous
that's beyond ridiculous, if we are referring to major brands and not "sleazy convenience store oil" - Pennzoil, Mobil, Castrol, Quaker State, Valvoline, etc. are filtered to a crazy degree, my bottled spring water I am drinking right now likely has more particulate than these high line oils, and used motor oil does by many times over. In fact, it is particulate that is responsible for most of the opacity and dark color of used oil. Black carbon is a particulate!
So the sae papers dnewton derives his data from is rediculous.
I'll explain it to you so you can understand.
Oil puts its own anti-wear layer on over time. When you change your oil the new oil strips the previous anti-wear layer off and puts on its own,so during that period wear metals increase. It's not "rediculous",its proven,to automotive engineers anyways.
So if you consider yourself to know more then by all means educate me. Until such time I'll consider your posts rediculous,and posted by a blowhard bitog know it all,who has no data.
