Do you know if driving with just the front wheels will damage anything like a transmission? They told me I'll be alright but I'm not sureThanks for the info.
It's pretty common on a lot of these cute utes, esp H/KDo you know if driving with just the front wheels will damage anything like a transmission? They told me I'll be alright but I'm not sure
Bad struts can absolutely cause these symptoms. On both an '02 Tacoma and '14 KL Cherokee bad struts make it feel like you desperately want a steering stabilizer....almost death wobble-esqueBad news.... taking out the shaft got rid of the cabin vibration but I still have the intermediate passenger side wheel bounce skid when driving on flat paved perfect roads...it's like the passenger side wheel looses traction and starts bouncing..you can feel it all over the dashboard when it happens. I'm thinking it's a cv axle... unfortunately where I live here in Greece they can't find me a replacement. I'll be more then happy to send money to someone that can send me one from the states
We replaced the struts and strut mounts last month thinking that was the problem... didn't solve nothingBad struts can absolutely cause these symptoms. On both an '02 Tacoma and '14 KL Cherokee bad struts make it feel like you desperately want a steering stabilizer....almost death wobble-esque
That's easy to check by pushing each corner down forcefully and seeing how much it bounces and how well it dampens. Also look for leaks on the piston and/or the entire strut will be caked with old oil and dirt
I'm not saying it IS a strut(s), merely that it's a possibility.
CV wobble is typically throttle dependent. Struts are "bump in the road" dependent, especially when one wheel hits an irregularity and the other doesn't
It sure could.make sure your wheels are spinning freely as a tight brake from caliper or pad or hose can do this also
Starting to think it might be my harmonic balancer...if it's that good luck fixing it here in Greece where I live. The car vibrates like a shudder randomly. Sounds like brrrr noise..when this happens it's in the passenger side towards the middle of the front. Even the dashboard rattles when this happens..I've noticed it happens after I go over rough roads. Even the slightest I perfection in the road sets it off. My right passenger side outter cv out is ripped and the joint inside might be toast but I don't think that's making this vibration brrr shudderIt sure could.
I'd chase motor mounts before I'd chase a balancer issue, given your symptoms. This is assuming it's truly an issue with the engine. I think even the mounts are unlikely, but have you checked them?? It's actually easy to check the front two with a pry bar.Starting to think it might be my harmonic balancer...if it's that good luck fixing it here in Greece where I live. The car vibrates like a shudder randomly. Sounds like brrrr noise..when this happens it's in the passenger side towards the middle of the front. Even the dashboard rattles when this happens..I've noticed it happens after I go over rough roads. Even the slightest I perfection in the road sets it off. My right passenger side outter cv out is ripped and the joint inside might be toast but I don't think that's making this vibration brrr shudder
The mechanics have not looked at the mounts..I told them to a few days ago but they said it would vibrate even in park which isn't true because I know alot of them vibrate even going 10mphI'd chase motor mounts before I'd chase a balancer issue, given your symptoms. This is assuming it's truly an issue with the engine. I think even the mounts are unlikely, but have you checked them?? It's actually easy to check the front two with a pry bar.
If a motor mount is bad enough that it's making the motor/transaxle sag, or lean down to one side, it can change the axle geometry and cause a shake or feel like a wheel balance issue. Usually does it under acceleration though.The mechanics have not looked at the mounts..I told them to a few days ago but they said it would vibrate even in park which isn't true because I know alot of them vibrate even going 10mph
If they're original they're almost surely trashed but I can't promise replacing them would fix your symptomsThe mechanics have not looked at the mounts..I told them to a few days ago but they said it would vibrate even in park which isn't true because I know alot of them vibrate even going 10mph
Yes mostly mechanicAll that interior vibrating over the months has put to the test all the interior pieces. Interior vibrations can only be found taking things apart. Best to start pulling interior trim pieces off to begin finding the source. Do you do much DIY? Seems like you are relying on a mechanic to do all your work.
No it won't necessarily!The mechanics have not looked at the mounts..I told them to a few days ago but they said it would vibrate even in park which isn't true because I know alot of them vibrate even going 10mph
You think it's the engine mounts thenNo it won't necessarily!
Could Be. sometimes, if an engine mount is real bad, it can change the geometry of the axle shaft(s) and cause vibration, shimmy, etc. Could do it all the time like my 01 Grand Prix, or, I can see the possibility, that if the motor shifts a certain way, the symptoms could/would come and go?You think it's the engine mounts then
