Canadian/Ontario Used Oil Analysis?
Ontario, Canada
I've read/searched up a few older threads, but was wondering if there is any newer decently priced places in Canada (Ontario preferably) that does used oil analysis by mail/will send a kit (or is in the Burlington/Oakville/Milton/Hamilton/Mississauga areas)??
I've got a 5.7 Hemi that does tick a bit so wanted to get an idea on whats going into the oil so I know if I should start saving or not! ;)
Will I be able to tell from one analysis or will it take a few? Never done one before :/
Thanks! :)
Thanks! :)
Petro Laboratories Inc.​
1295 Matheson Boulevard East, Mississauga, Ontario, Canada, L4W 1R1
(905) 361-2388 https://petrolab.ca/
I know nothing about this place; I have never used them.
Fluid Life has a place in Brantford.
That is Toromont Cat right?
Anyone actually tried any of these Canadian ones?!
Finning is the Cat dealer for western Canada—Toromont is the dealer for Manitoba-east.
As a Toromont technician, I’ve taken and reviewed hundreds if not thousands of oil samples over the years.
You can mail sample bottles or drop off at your local Toromont branch. Not sure how the price compares with others.
As for your tick…the first thing I’d do is cut open and inspect your oil filter. If there are very high levels of wear metals, it should be obvious with one sample. Best practice would be to sample regularly and watch for anomalies.
Thanks! :)
I'm in the golden horseshoe and just ship it to Blackstone. I think it took like 2 or 3 days last time for them to analyze it once the packaged arrived.
I also have a 5.7. Best thing you can do for these, drop the oil and put in a good 30 grade. Bunch of us run HPL, Redline, or Mobil 1 FS 0w-40 with a shot of biotech lubeguard (the lubeguard is only used with M1 0w-40, not with HPL/RL as HPL has gobs of moly already, and RL is quite good in that area too).
The common theory is that these engines do well with a high dose of moly which those oils do have. It may reduce/eliminate your ticking noise, but the tick isn't necessarily a symptom of cam/lifter failure as these engines are quite noisy, especially on a cold start with cheap thin oil. Once the engine is hot, running a good 30 or 40 grade, and bonus points for moly... they quiet down.
Couple other reasons a hemi could tick:
- noisy injectors (super fast and light ticking)
- exhaust manifold tick (most noticable on a cold start, reduces/goes away as it heats up)
- thin oil
- lifter/cam failure
Not all failures show up in UOA reports. A UOA is looking for a tiny microscopic window of iron/wear metals. UOA's are best used by establishing a base line over time, and then if you see wear metals trending up over 2+ samples (or a huge spike in the latest) you can usually tell something is wrong. But for your first UOA, it won't really tell you much.
If you can post a video of your engine making the noise we might be able to guess one way or the other what it is.
I have always used Wearcheck in Burlington. I worked right up the street from it for many years and would just drop off my sample right at the lab. Often I would get the results within 24 hours!
