I'd keep it synthetic due to the short tripping and the fact that it's brand new. I'm sure you want to keep it that way. Being in CT too, it would make perfect sense to use a 20 grade in winter....and a 30 in summer. While under warranty try to use the highest viscosity 20 grade you can find that still meets mfg specs. If it were my truck I'd follow the warranty....until it expires...or until you have enough proven research to show that a 30 grade would be better for your engine.
After the warranty is up...no brainer imo to step up to a 30 grade. Any of the Sopus oils are fine (QSUD, QS synblend, PP, PUP, Formula Shell Synthetic, Pennz Gold synblend, etc.). I don't see a huge difference in PUP vs. PP. Both are good. And the PP is so readily available and almost always on sale/mfg rebates in play. The recent AAP QSUD clearances could have given you a few years worth of 25c-95c/qt oil.
If you're new to the "oil game," you'll be learning a lot more over the next couple of years, and will probably change your opinion on oils a couple more times. Good luck. We are always learning.
