- Joined
- Sep 24, 2023
- Messages
- 1,457
I saw the champ labs filter posted.
ST is made by Champ-it has been postulated that the only difference between the ST 10K & MP 20K is nitrile vs. silicone ADBV. The CQ Blues & Reds have been made by just about everyone... From Affinia/Wix, to Fram/Champ, then Mann/Purolator (Wix-ish), back to Champ again...I thought super techs are identical to a champ labs
I have 153k on her. I got her at 58k and she has had either Pennzoil Platinum or Mobil 1 0w-20 since. High mileage from 70whatever on. She has always burned a bit of oil, but it is only in the past year of so that it increased dramatically. During this OCI I have put ~4.3 quarts in over 3000 miles, so it is to the point that I am willing to try mechanics in a bottle to bring it down. Four years and 40k miles ago I was adding 3.5 per 5500 or 6000 miles.
Your car has the notorious 2AZ with low tension rings. If it didn’t get a new short block, it will eventually start burning oil. You have to burn a ton of oil to even get close to justifying a new short block or engine. If you pull a spark plug and drop a bore scope your cylinder walls will have had the cross hatch polished away, and have vertical score marks.
The Champ XL is the same as the Supertech MP. The filter media appears to be the same of the Fram extra guard.
A short while after I bought the car I dug into the oil burning issue, which was discussed at length over on the toyotanation forums. Toyota really should have had a class action lawsuit against them for the defect. They got away with an extended warranty-type offer but my car didn't meet the 1.2quarts burned in 1100 or 1300 miles at the time to get the pistons and rings replaced. Mine was doing relatively well until the pandemic when changes in driving habits exacerbated the issue to where it is now. I'm going with 30 viscosity oil and trying a few runs with HPL Engine Cleaner to see if that cuts down on the consumption at all. Otherwise the car is still in good condition so I might just cross my fingers and replace the spark plugs and change the oil a bit more frequently for as long as the engine holds out.
Someone might say, time to bust out the BFH, metal rod, & antifouler... My brother's old Accord & Trailblazer have both had this done (not by me, I don't want the potential fine!).It’s hard to have a rational discussion about Toyota. They’re just a car company and they manage cost at all cost. The rings and pistons weren’t much of a fix.
Those engines are hard to kill as long as you keep oil in them. It’s going to kill the cat or the cost of oil, like a quart every 100 miles, becomes excessive.
I have a whole case of champ ph 2835’s. Tan them for years at my work without issues.I saw the champ labs filter posted.
1. The official ratio is 20% of oil capacity. If you’re talking 0.25 qts or so to be “perfect”, I doubt you need to be so critical. Your sump would take 29 ounces to be perfect, so a quart would be fine IMO.
2. EC is a bunch of specially chosen esters to soften and release carbon and varnish and other solids that have precipitated onto lubricated surfaces. The regular engine oil takes this up a notch with alkylated napthalenes, but this can be a little aggressive in a dirty engine- HPL recommends at least one OCI with just the EC to gently and safely remove contaminants without plugging the filter or other engine passages.
In the case of an oil burner likely with coked oil rings, a couple OCIs with just the EC is a safe way to free those rings up. After consumption is down, you can either:
A. Switch over to HPL’s regular oil and motor on; B. Continue nearly indefinitely with simply subbing a quart of EC into your choice of oils; or C. Go back to whatever shelf stock oil you prefer and do a quart of EC say every 10-15k miles. Your choice, all are likely better than your current condition.
3. The EC is fully formulated and has HPL’s normal additive pack which is almost certainly more robust than any shelf oil, but you don’t want to run a full sump of EC because if the ratio is too strong it can affect some of the polymers from what @High Performance Lubricants has shared. So, EC + shelf oil for a few OCIs, then proceed in step 2 as you wish.![]()
I’m hardly the resident expert when the CEO @High Performance Lubricants is on board, and @RDY4WAR is an excellent source as well.I'm just curious since you seem to be the resident HPL expert, do you think I should go with the standard sized filter (M1-103A/PLB14477/Champ PH2048XL) while I run the HPL through it each OCI, or should I up to a larger filter like the Fram FE3614/3600? If the HPL works it should be knocking off crud that will circulate so I don't want to overload the filter and cause it to bypass.
