XG3675 Replacement
Basically, what I'm looking for is a 3675/51522 equivalent 4" tall filter with a mesh backed media and at least 99% @ 25 microns efficiency.
Purolator is the only one willing to share an official specification sheet. The Carquest Premiums & Oreilly's Microgards are really well built filters & will do everything you need them to except efficiency spec since that's not known.
Contrary to their own documentation, the FE9837 DOES have an ADBV! The proof's in the pudding.
9837
3506
I'm trying to summarize what I've learned here? See any errors or omissions?
Wix 5152299% @ 21µm$8.33Amazon
Fram XG367599%+ @ 20µm$12.90Walmart
Fram FE983799% @ 20µm$12.97Wire backed mediaWalmart
Royal Purple 20-5999% @ 25µm$18.99Wire backed mediaO'Reilly
MicroGard Select MSL5152299% @ 25µm$9.99Captured bypass valve, coil springO'Reilly
Carquest Premium Blue 8552299.5% @ 20µm$6.23 / $7.79Captured bypass valve, coil springAdvance Auto
Looking at their website pictures it shows Microgard with a silicon Oring gasket while the Carquest does not. Go to the store to actually look at these filters before making your decision. Good to know if the Microgard & Carquest are actually different.
can confirm that new stock has silicone O-rings. that is my go-to filter to put on all of the LS swap projects we do. old stock i’ve seen is still premium guard just without the silicone O-ring.
Which brings me to the next point I was going to make to OP since they're the same (I assumed the same as well) but thanks for actual confirmation.
May have to "click to expand" for you to see my bold.
See how @BrendanC confirmed most likely the exact same PG built filter but one claims one efficiency while the other higher efficiency. Obviously, it's a shot in the dark for what it actually is & until you see a spec sheet for that individual filter you'll never know for certain. However, as I & others have mentioned here those filters have a very good build quality. IMO deserves to be run as most other filters for OEM Drain intervals or slightly longer (10k rating).
I can confirm. This is for a different application, but I just bought it yesterday.
