Sound like DI to me. Does the generator tick and clack?You sure you’re not hearing the generator come on and not the engine. The generator is loud as well.
Not following this question-the engine is the item powering the ”generator” portion of the transmission.You sure you’re not hearing the generator come on and not the engine. The generator is loud as well.
Regarding 0w16 there seem to be two camps, you should never use it or you must always use it. I’m the outlier I guess cause I say you can use it but you don’t have to use it. Other viscosities are certainly allowed however so is 0w16. If the weather isn’t extremely hot and you’re not towing or racing then 0w16 will be just fine. But so will the higher viscosities.
I’d venture to say the hybrid battery or system will be the first big ticket item to go out causing you to get rid of the car. Not the engine. And even with 0w16.
It’s doesn’t matter. It’s been discussed many times.The manual says to use 0w16, and it says you can use the next highest one once. Then you must use 0w16 again the next oil change. Both of the oil change places I went to told me this as well. So maybe it's important on the hybrid. I know some toyotas started using low pressure piston rings.
You mean low tension rings. They've been around a LONG time in MANY engines. Trust all the people telling you this engine runs fine (and is probably protected better) with 0w-20 instead of 0w-16. My Camry 2.5 (not a hybrid) also specs 0w-16. I've been running 0w-20 in it for every change (which is about 5000 miles). It has only 76,000 miles on it now, and the oil stays clear/golden the entire time, and stays dead on the full mark, and we get upper 30's to low 40's mpg. One trip, with 3 adults going no faster than the speed limit, it got 53 mpg. On another trip of 800+ miles in one day, sometimes running 90 mph (if I recall correctly, I averaged over 70 mph, and that included two complete stand-stills on the Interstate for several minutes each time), it still got right at 40 mpg. Nothing magical about 0w-16.The manual says to use 0w16, and it says you can use the next highest one once. Then you must use 0w16 again the next oil change. Both of the oil change places I went to told me this as well. So maybe it's important on the hybrid. I know some toyotas started using low pressure piston rings.
And it is not.It’s doesn’t matter. It’s been discussed many times.
The same 0w16 at -5F in Minnesota during the winter and 105F in Arizona during the summer are going to be vastly different. The engine cannot be that sensitive to oil without being harmed at one end of spectrum or the other. It just cannot.
Does the manual say either?That's meaningless if they told you not to operate the vehicle in those temperatures. Or to change things up if conditions change.
Didn’t say it would, don’t try to change the subject. A UOA will say what condition the oil is in. If it is still good then then 10,000 mile drain interval is not decreasing engine life.UOAs really do not tell you much of anything about what's going on inside the engine.
Take into account the engine converted gasoline into work sufficient to move the vehicle for 7500 miles.Remember to take into account that your engine is not running all the time. At 7500 miles the engine might run 5000 or so of that.
Haven’t watched that video in a while but I thought he also said the Dr had dealer bulk oil services. Had he used M1 or another top tier oil would this had happened? Who knowsIf we go by the word of the former toyota tech in the video, the 10k oci caused that doctor's car to wear the cylinders out. And the engine's life was spent at 150k miles. He said it's because gasoline gets to stay in the oil longer when you run oil for 10k miles. Breaks it down and turns it into much crappier oil.
Maybe I'm unaware of it because I'm not a veteran member like many of you guys, but I don't know of any filter which filters out the gasoline that gets mixed in with your motor oil.
Daughter in law bought a 2008 Camry hybrid with 262K miles on it. It says 0W20 on cap and in manual. I have 5w30 on hand, that’s what it has gotten the past three oil changes. Fram TG4967 changed every other oil change. I drained/refilled the radiator, did a drain/refill on the inverter, drain/refill cvt with Toyota WS. 5000ish mile oil changes. At 272K miles now and runs like a champIf I owned a Camry Hybrid (and I wish I did at current gas prices) I'd change the oil and filter every 6 to 7.5K using
0w20 (because it's easier to find and I have some already) and a WM 10K filter. If the filter is difficult to access I'd probably use the Fram Ultra for 2 OCI's.
