Originally Posted by dblshock
I realize W20 oils have advanced since I first used them with my new '03 Accord and yes they probably do work in select circumstances but by far and away most using it experience oil consumption after 50k...if your ok with that be my guest it's your equipment...my advice is upgrade right off the bat and avoid the 50k of wear before you then conclude to upgrade.
As I said, I'm going to do a screening/baseline UOA at 10k miles anyway. I will suspend making a conclusion regarding whether there is or is not wear until then. Respectfully, you're just assuming it will happen. Can you show me a provable example (really, not internet sarcasm, if it's there, I want to see it! And I'll judge it fairly)?
And again, even if there is some added wear (which we can't just assume), the last twenty years of real world experience has clearly established that 20wt engines are lasting for as long as the cars containing them remain usable on the road. That's simply undeniable at this point, here in 2019.
I'm not declaring with certainty (as if I could know) that 20wt oils are the same, better or worse than the 30wts as far as wear is concerned. As an example, consider hypothetically that Castrol's right that most engine wear occurs during the first ~20 minutes of engine operation (see their Magnatec advertising blah-blah...). Assuming that's true, then the 20wt will be flowing "better" (compared to a 30) throughout the entire warm-up time, until it reaches full temp. Which is "better" here? And on and on.
