Originally Posted By: vinu_neuro
A lower viscosity here may improve mileage, but won't the viscosity be lowered severely (beyond the low starting value) as a result of fuel dilution.
The proof is in the pudding. No, it won't. It'll be reduced a little bit, but certainly not "severely" and not out of grade. There is an entire forum section of UOA's, and I'll bet you can count on one hand the number of UOA's where a 20W oil has sheared out of grade. Secondly, if you're doing a lot of short trips, the oil spends most of its time being thicker than ideal anyway, so a slight amount of shear really isn't a big deal.
Oils are more shear-resistance, and fuel injection reduces the amount of fuel dumped in the oil, so in practical terms this just isn't an issue.
Shear resistance is fine in most oils. Fuel dilution is a different issue and a serious one in short-trip use.
Short trips, particularly in a winter is hard on engines and shortens the life of motor oil for a number of reasons including the possibility of fuel dilution. But since the oil is not getting up to temperature even a diluted 20wt oil is still thicker than necessary under such operating conditions.
