C1 vs C3 lubricants, the OM646LA Engine Wear Test
OVERKILL
$100 Site Donor 2021
Ontario, Canada
Thanks @Shannow for sharing this with me!
Presentation can be found here:
https://cectests.org/assets/presentations_publications/cec09_1993.pdf
The reference oils are interesting:
Development partners that we would recognize were:
- Oronite
- Lubrizol
- SWRI
- Shell
- BP
- Infineum
Both reference oils are ACEA approved. SA in the C3 oil is considerably higher (0.75%) than in the C1 oil (0.50%). I expect the C1 oil has API levels of phosphorous, while we know some of the C3 oils, like M1 X3 0W-40, have basically the same level of phosphorous as a full-SAPS oil (900ppm vs 930ppm for FS 0W-40). The impact this has on both the older and the current test results is significant.
Thanks O/K… lends even more weight to my thread/question about how poor the API “standards” are, and shoots down the ludicrous claim I was trolling.
These are Euro tests, with higher levels of protective compounds, and results show extremely poor piston cleanliness. What exactly do people think an API oil subjected to OM646 would show?
To me, valvetrain varnishing is a leading indicator that the oil rings are going to be packed full of CRAP and oil usage is soon to skyrocket…
I've mentioned this before, When we went from A3/B4 oils to C3 oils, I noticed an immediate and impressive reduction in engine cleanliness. The engines didn't blow up, so who cares, right?
I've stayed away from C3 when I could, for my own cars.
Note also that besides the additive levels, the viscosity is also different in the above tests, which can have an impact on wear aswell, and specifically on the rate of additive utilisation
No it isn't. You posted the ACEA 2016 sequence, which did use the OM646LA for diesel engine wear testing, but the current ACEA sequence is the 2021 edition which no longer uses the OM646LA.
I put "current" in quotes, because the test was used long after 2009, the date on the paper. Unfortunately, Afton stopped publishing the Handbook after 2019 (thats what those shots are from) so I'm not sure if Mercedes continued to use the OM646 sequences after 2017.1 or not (the last version in that handbook).
Could someone please summarize the the results for the less educated of us on here to help with understanding?
Also, around the time that these ACEA 'C' oils were starting to get used, manufacturers were extending OCI's. As you're aware, most manufacturers here on this side of the pond push 18-20k OCI's.
Shame this test didn't include an A3/B4 'control' or comparison.
The thinner oil with the lower SAPS (C1) had significantly more wear and deposits than the thicker 'mid SAPS' oil (C3).
Hi! What about low reference oil and high reference oil respective NOACK?
I recall ACEA C1 was made to be an ILSAC GF-5 sibling, request from some Japanese and American automakers.
I don't know nowadays, but some years ago, Acea C1 allowed 15% NOACK whereas all other ACEA categories allowed only 13% NOACK.
This allowed C1 oils to be particularly crappy and made with very low tier base oils, in regard of C2 and C3 categories.
Usually, NOACK reduces as base oil thickens.
Furthermore, usual C3 oils NOACK have NOACKs between 9% and 11%.
This enormous gap between repective NOACKs make a huge difference in quality between the two reference oils, making this study a bit tricky.
It would have been a less result-oriented study to compare ACEA C2 and C3 oils.
That was the first version of the test, which they found needed to be revised, because it wasn't producing accurate results.
Ah, makes sense. Thanks for the clarification. Well, I am glad I am trying out HPL 5W-40 in my M272 as next fill.
