Originally Posted By: kschachn
Originally Posted By: sciphi
I think the issue was daisy-chaining the outlets together, and a massive load somewhere downstream previously. The previous owner had a large A/V setup and a large computer station in that room all on that circuit. We don't have anything near that large on it, just a LED TV, router/modem, and a 27w LED lamp.
I understand but that circuit should have been protected by a 15A overcurrent device, either a circuit breaker or a fuse. So it should have seen a total current of 15A or less regardless of how many appliances were simultaneously connected to the circuit. One would have thought that if the method is UL approved it would have safely permitted 15A without burning the wires. But clearly that isn't the case.
IIRC I flipped a 20A breaker.
Your explanation makes sense why some of the wires were burned. That breaker also wasn't labeled like all the other breakers in the box, which suggests it was replaced at some point. Probably because a 15A breaker kept tripping.
I wonder what other Easter eggs lay in the wiring now. Blankety-blank previous owners...
