Originally Posted By: JHZR2
So the question comes to WHY YOU need a ground, as a computer buff - electronics or general safety. A GFCI-protected grounding-type receptacle without an equipment-grounding conductor is safer than a grounding-type receptacle with an equipment-grounding conductor, but without GFCI protection. This is because the GFCI protection device will clear a ground-fault when the fault current is 5mA (+ or - 1mA), which is less than the current level necessary to cause serious electric shock or electrocution.
Agree with you there... GFCI makes it safe. Surge protectors won't work as intended, so if that is a concern a UPS could be used instead - it will switch to battery in the event of a surge that is actually harmful to the equipment.
Modern decent quality switch mode power supplies usually operate just fine anywhere between 100 and 240 VAC and are surprisingly resistant to poor power conditions. No plug in surge protector will do a thing against direct lightning strike, grounded or not... so there really isn't a ton of risk.
This is just one of the joys of an older house. There are probably far bigger issues such as a lack of insulation and leaky windows that will lead to high heating bills in the winter, which would worry me more than the ungrounded outlets.
