Wow that's really disappointing. Considering all that you've discovered so far, if I were in your shoes I'd demand my money back and call LKQ to find a low milage long block from a wreck. With a fresh water pump and timing belt you'd be back on the road in no-time.
Originally Posted By: nola000
Quote:
Lots of opinions here and it sounds like you've already made up your mind, but I'll share mine anyway.
Not at all. Im here to learn. I just want to hear sound logic and reason or advice born from experience.
Quote:
You're thinking about this too hard. This is an econobox 4-banger, not a top-fuel drag motor.
Im not worried about HP. This is a commuter car for my wife. It needs to be maintenance free, not burn oil, fuel efficient and most importantly, last forever.
Quote:
Unless perhaps your motor was built by some inexperienced vo-tech student and not properly hot tanked after machining
Well, it was rebuilt by JIS in Arlington, TX. They did a chit job from what I see so far. They have all the right equipment but it looks like its a production line and they dont go through proper inspection and spec check of the cores. I just got it on the engine stand and so far it had two of the engine-to-transmission mount bolt holes were stripped out, overspray everywhere, leftover gasket material on the cylinder-to-valve cover mating surface, over torqued valve lash adjustment nuts, I suspect over torqued everything else based on what I checked, some unsettling grinding feel when turning the engine over by hand, out of tolerance rod-to-crank clearance(service limit 0.4mm, measured 0.7mm), etc.
