So threw this site I have seen 2 sides to using synthetic oil during break in. many say its fine to use synthetic and MANY cars come with synthetic from the factory. Alot of people say this is because of new manufacturing processes and the break in is not as crucial as It once was.
others say you need to stay away from synthetic during break in to allow the rings to seat properly. this seems to be an "old school" thought.
well what about building an engine at home? I have an engine I need to break in that was recently Honed with honing stones. Also the piston is a NOS race piston and is from the late 70s to early 80s.
I am looking for a Motorcycle oil that is safe for wet clutches and also has a robust add pack for this engine. Its going into an 1984 atc110 that i have modded. (race cam, stiffer valve springs, big bore piston 10.5:1 compression (cylinder is bored to max) larger carb ect...) Its an air-cooled single cylinder SOHC engine. I really like the looks of Mobil 1 4t and its the correct oil weight and I would like to use a synthetic because it is winter here in Michigan.
But im unsure about using a synthetic oil for break in on this engine since its "old school" and not built like new cars today.
I have actually already built it once and used it for a few hours to find that it was burning alot of oil. the cylinder was lightly scored on the top and bottom (the cylinder sits horizontally) of the cylinder. Now I theorize 2 reasons for this. when i broke it in i did not put load on the engine. we ran it alot on our barn in neutral as we were trying to get the carb and intake dialed in. I read articles now that say the engine needs to be put under load in order to seat the rings properly.
I also used Honda GN4 which appears to be (thanks to this site) a very boring oil with nothing going for it. it is conventional. Because my engine is not stock i worry it needs more then what GN4 offers.
so this time breaking it in I want to use a different oil thats better and Im not sure if I can use synthetic. I am having a hard time finding a Conventional oil thats JASO MA rated that has a robust add back like ZDDP levels higher then 800...
the only thing being broken in will be the rings and cylinder. the cam and rest of the engine already has 2 hours on it.
after it is broken in i plan to use synthetic because it will mainly be used In cold winters.
