Hi, first time post here! I just bought a Toro Z-Master 3000 Series commercial mower, and it has a Kawasaki FX730 V-Twin engine. The engine manual recommends changing the oil at 8 hours, however it doesn't specify a particular weight of oil or type. The manual has a diagram of SAE30, SAE40, 10W-30/10W-40, 5W-20 all being okay to use (based on outdoor temperature per the chart depicting this info).
I was thinking running 10W-40 dino oil, and was looking at oils on Kawasaki's engine website. They have their K-Tech line of oils. It mentions the following:
10W-30, 10W-40, and 20W-50 synthetic blend oils provide ultimate performance and protection in both low and high temperature applications, including cold-weather startup
Is this oil truly synthetic, or just a multi-weight oil? I was under the impression that I'd want to hold off for quite a few hours before switching to synthetic. What does everyone recommend with these air cooled engines? Thanks!
