- Joined
- Feb 22, 2021
- Messages
- 2,205
Yep, we have to do the safest thing which involves declaring an emergency at times to get priority handling ( fuel emergency ) or to deviate from a clearance, but risking safety by flying into active military airspace or descending too low when terrain is an issue isn’t improving safety, it’s dangerous.This is a case where that Southwest pilot put himself and his passengers at risk. If ATC couldn’t grant deviation around the weather, then maybe it’s time to turn back, hold, or do something else. But wandering into active military airspace, particularly in Nevada, is downright dangerous.
Active military airspace means just that. Fighters, and other tactical aircraft, are maneuvering at high-speed, and under high G.
They may or may not be looking for the airliner that blunders into their war game. They may or may not see it, because they’re busy looking at the airplane at their six. There may be anywhere from one to several dozen airplanes in that airspace. The southwest pilot had no idea how many, or how close, they all were.
The risk of penetrating active military aerospace includes getting shot down, having a mid-air collision, or being too close to ordinance when it’s delivered and explodes.
Also, and I think this really important, when that airliner does blunder into active military airspace, the entire exercise will be called off for safety and every participating airplane will stop their training. Depending on the nature and size of the exercise, you just cost the taxpayers of the US, and perhaps other countries, millions of dollars in wasted sorties. And that pilot may not care, but somebody does.
Now, the military is pretty careful about all that stuff, and I’ve organized several missile shoots.
Those missile shoots took place over the ocean, in W-72 and other airspace, and we made sure that no airliner had blundered off of the prescribed jet airways before we released several missiles at the target.
My point: Declaring an emergency does not change the reality of the situation.
I’ve had this issue arise when debriefing crews after simulator training when they failed to comply with the step down fixes on an ILS in mountainous terrain. In fairness to them, they were pretty task saturated, because I’d already given them an engine failure as a result of a fuel leak or an oil leak. So they had to fly this ILS with an engine out, in addition to the terrain.
I’ve had several captains say “I declared an emergency, so I don’t have to follow that clearance.”
Well, does the terrain know that you’ve declared an emergency? Do the mountains suddenly get lower, or move out of your way, as a result of your emergency declaration?
The exercise of emergency authority can be a double edged sword. You have the authority to do lots of things with your airplane. That’s an important authority.
But just saying “Mayday” does not change the fact that you were flying towards a mountain, or towards active military airspace where you’re subject to increased risk of a mid air collision.
I have never been too low on fuel, not yet.
I had to answer ( ATC understood ) for declaring those emergencies , the chief pilot called. He agreed I made the right call.
