Leakedreality.com
leakreality.com
Yeah, that was more than a simple loss of power where you can at least try to glide it down. He looked to be well above stall speed. RIP to all. That was ugly.That poor UPS driver. Talk about being at the wrong place at the wrong time. That thing was screaming when it hit.
That’s what I’ve heardDidn't the old V-Tail Bonanza's first start the term, "Doctor Killer"?
Flying an airplane, even takeoffs, landings, maneuvers are not difficult. It requires a bit more skill than driving, but most airplanes are inherently stable and anyone with normal coordination can learn to do it safely. What kills most pilots is lack of judgment. Which makes it similar to motorcycling.To me flying a plane is like driving a Motorcycle on an icy road,, I just do not have the skillset.
I had a friend that was a flight instructor for a few years . When ever there was an opening in his schedule I would get an introductry lesson and I I could land and take off a Cessna 152. I had the confidence I could do a solo flight but flying in not my thing. I love planes any type plane and like going for plane rides. Piloting is not for fools . So I am.Flying an airplane, even takeoffs, landings, maneuvers are not difficult. It requires a bit more skill than driving, but most airplanes are inherently stable and anyone with normal coordination can learn to do it safely. What kills most pilots is lack of judgment. Which makes it similar to motorcycling.
"As a pilot, I will use my superior judgment to avoid needing my superior stick & rudder skills."
How much time do you have in twins?Flying an airplane, even takeoffs, landings, maneuvers are not difficult. It requires a bit more skill than driving, but most airplanes are inherently stable and anyone with normal coordination can learn to do it safely. What kills most pilots is lack of judgment. Which makes it similar to motorcycling.
Agreed. I don't fly twins, and for good reason. Common perception is that they are safer (how could they not be, with 2 engines?). Many people don't realize that 2 engines means twice the probability of engine failure, and in a twin, engine failure is more dangerous than in singles, unless the pilot is proficient and current and on top of his game at the moment it happens. Sadly, that is not always the case, especially in GA which doesn't have the discipline and operating standards as commercial and military.How much time do you have in twins?
A twin with an engine out is anything but stable.
There is the Cessna 336/337 Skymaster twin, one engine in front, one behind, no differential thrust if an engine fails, so no Vmc. So if you use that airplane to get your multiengine rating, it comes with a centerline thrust limitation.
Hmm. Wonder if he became disoriented due to a CO leak from the engine or a buildup of excessive C02 in the cabin?The ATC recording suggests the pilot was getting distracted and behind the airplane leading up the the crash. Multiple altitude warnings from approach/tower, sounds like he thought he was climbing.
