Picked these up at NAPA for $28 for my friends Silverado. He needed the job done fast and isnt super picky so I found these online and was curious enough to look at them in person.
I have probably installed 50 plus sets of brakes on GMT400 and GMT800s so i feel as if i can give a fair review from the installation process.
Cons- No name that is recognizable, Nowhere on the website or box does it say if they are Ceramic or Semi Metallic..
Pros- Unless im reading the codes wrong, these are GG Friction Rating pads..which means that they are ceramic? These pads also had hardware included.. rarely do i get a set of pads with hardware that fit..these do. These pads also needed no filing.
Made in India it says on the box.. and the shim bag said Made in China
My previous 6 installs have been Raybestos Element 3 pads, all of those boxes said Made in China.
I will report back if he says they squeak or if he has any complaints..but these pads seem as good if not better than any pad ive installed in the past few years.
Pads removed were NAPA Semi Metallic FE friction code, glazed and had heat cracks..about half a pad left.
