I'm going to just say it. Most neglect their brake fluid. It took me a few decades to realize how easy and cheap it is to bleed fresh fluid into the lines yearly and the braking difference with $5 in fluid is HUGE.
Recently bought a 2014 Caddy ATS, and extracted a brown slurry from the brake lines. It's going to get two full bleeds over the next month. My wife commented "OMG, what's wrong with those brakes".... because she so used to my mint maintenance of brake systems on our cars. The brakes were fine, but the fluid was terrible.
Benefits of regular bleeding:
- much better peddle feel and response; can make the difference between hitting the moose, or not.
- Keeps contaminates out of your brake lines which are no doubt rotting things from the inside.
- Calipers will last longer
- Pads/Rotors will wear better
- Less brake fade under heavy/continuous braking; Having a cabin in Cape Breton highlands exposed old fluid quick driving those roads.
- Less likely to be stranded due to a seized caliper that rotted from the inside (happened twice to me before I learned).
I don't care the brand. I used ST DOT3 for the van, along with a full four corner brake tear down, lube, rebuild with new rotors, pads and final bleed. Brakes are so good it's silly. The job cost me $300, including shop supplies. Now it gets $5 of fluid a season and brakes get an annual cleaning for the next 50k.
This is a repeat for the old timers, but could be good info for new BITOG'ers.
