edyvw
$50 site donor 2026
LV is bit better when things get super cold. It should improve ESP operation.Just did a full flush on a BMW 3 series, along with replacing the pads. Be aware that for some vehicles, as with mine, it's not just DOT 4, but DOT 4 low viscosity brake fluid that should be used. The majority of readily available brake fluids at your local auto parts chain are NOT low viscosity. After some research I was able to identify Motul DOT 4 LV (Class 6), Pentosin DOT 4LV and ATE SL6 DOT 4 LV that meet the low viscosity criteria and are carried or can be easily ordered by my local auto parts retailers.
However, I used regular DOT4 forever, especially on track in BMW.
As for do you have to use LV? No you don't.
