Originally Posted By: JavierG
If Honda recommends 10W-30 why would you go to a 0W or any other weight?? They backspeced some of their other vehicles (for example: for my Ridgeline originally Honda only recommended 5W-20 but was backspeced to also allow 0W-20) but the S2000 has remained at 10W-30.
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2251258
donnyj08, congrats on a great find!!
Honda assumes you would be using conventional 10w-30, which is this most shear stable in Honda's mind. By using a synthetic, you are now exceeding the requirements of the car. A 0w-30 or 5w-30 synthetic can provide the same or better shear stability than a conventional 10w-30 with all the benefits of a higher viscosity index.
So why didn't they show 0w-30 on their chart since it doesn't come in conventioanl?
Are you sure they are assuming that a conventional will be used? Or are you assuming that they are assuming?
Honda S2000 2004 Owner Manual:
Always use premium-grade detergent oil displaying the API Certification Seal. ...
An oil with a viscosity 0f 10W30 is preferred for optimum fuel economy and year-round protection in your Honda. You may use a 5W40 oil if the temperature in your area goes below 0F(-20C)
Synthetic Oil
You may use synthetic motor oil if it meets the same requirements given for a conventional motor oil: it displays the API Certification Seal and it is the proper weight. You must follow the oil and filter change intervals given on the maintenance schedule."
Clearly conventional is recommended and synthetic is an option.
