- Joined
- Jun 9, 2021
- Messages
- 156
Definitely not ideal. Had a couple of low oil pressure codes (last thing I want to see in an N55) and decided to spin off the filter cap on a whim.
This was a Bosch workshop filter I got for cheap on RockAuto. I always check that the cage is properly snapped onto the filter cap on these and ensure that the filter is properly seated before spinning it back on.
I've owned quite a few N series engine cars by now and noted that this oil filter fit very tight, the o-ring for the stem was difficult to get on, and looking back it probably required more force to tighten down than usual. I imagine the dimensions on this weren't quite right causing it to get crushed.
Additionally, due to the tight fit, the cage holding the filter separated from the cap when undoing it causing the filter to remain in the housing and oil to spill all over my engine bay, ruining my brand new serpentine belt in the process.
What concerns me is that bit of plastic missing from the top endcap. Wondering where that ended up will probably keep me up at night.
Thoughts?
