BMW e46 M3 Oil Report. Looking for some opinions.
Atlanta GA
Hello Everyone...New here.
I find myself on this website from time to time and decided to post. Below you will see my report from Blackstone. The s54 had a bearing recall that was performed on this car when it had about 20k miles. At first my lead was high but I did some smaller oil cycles and lead went down but then went up recently again with the latest oil analysis where I used redline 10w60 instead of the standard bmw recommended castrol 10w60. Just wondering your thoughts on the trend you see in my report. Thanks for all your insight.
Red Line 10w60 is thicker than the BMW 10w60, FYI.
A slight bump in lead is nothing to worry about. People are too quick-to-panic when they see a slight elevation in something. The fact that wear metals are DOWN from the last few reports suggests things are actually doing better.
I would switch back to the TWS and keep on driving.
Originally Posted By: Brybo86
fuel lowered the flashpoint a bit too
FP is down, but I would not worry. Doesn't seem to be hurting anything.
