We recently got an E92 320i for one of the family, which means I won't be driving it, but I will be responsible for the maintenance. Its done about 72k miles, and already had a new timing chain apparently as a preventative maintenance according to the seller who was only the second owner. Its got pretty good service records at BMW and indie garages so I was expecting a pretty clean oil change... it wasn't as clean as I expected - but still nothing super alarming I think. With a reduced OCI, it should be fine for many years to come.
Here is the filter. No metal, but some black sludge or bits of silicone, not sure:
The filter housing, I poked around the small hole which released some fine particles. I poured fresh oil down into here to try to wash out as much as possible. I'm not sure if that small hole is meant to be blocked/closed when the engine is off, but it doesn't seem to lead to anywhere.
There appears to be a small nick in the filter cartridge itself. I have no idea how that could happen, but I think I'll replace it at the next oil change for peace of mind:
This is the oil I used:
The joys of used car buying! Even something with good records might not be as good as expected, but otherwise its a pretty nice car. Its probably the first BMW I've experienced that rides really comfortably, since I've only ever been in friend's BMWs which have been sportier variants and M cars.
I'll do another oil change in 4-5k miles and see if the filter comes out clean and report back. I'll also be changing all the other fluids and filters pretty soon.
