BMW B58 Engine Oil Recommendation
Because even as much as I respect @edyvw and his technical knowledge, it’s still an opinion.
My “list” might be different, at least if I had one. Unfortunately I abhor ad hoc rankings.
I don't put a lot of stock in the actual lists, but I think finding out why knowledgeable people might list items in different orders is a good way to learn more about their thinking and, thus, learn more about the topic.
So, when I see a list that doesn't comport with what I thought it would be, it sparks some curiosity in me.
Really, just inquiring about his list as an exercise as I try to learn, not trying to come up with some definitive list.
Oh, geez-- yes, it was the 0w30 (not the 5w30) that you aways recommended.
Sorry for the confusion!
Still wonder why the Castrol Euro 0W-40 didn't make the list and why the Castrol 5W-40 was in last place.
IMO, with API SP, there is no difference between Castrol and Mobil 1 0W40.
Old API SN Castrol 0W40 had higher HTHS than Mobil 1. If going online to get 0W40, IMO, 0W30 would be better choice.
Great-- thanks for the response.
My old-school pushrod engines (plus the Mitsu 1.2l I3 in the daily drivers) are non-fancy, non-fussy, and pretty much anything would work in them, so I tend to go with the cheapest thing I can find.
I got in on that Amazon deal for 5qt jugs of Pennzoil Euro L for $14.13 a piece, making it the cheapest oil I've found (much to my surprise!).
I feel guilt putting that high-zoot Euro L in such low-end vehicles! :)
But now that I'm in the game, and good deals are to be had on a pretty regular basis, I've been doing some reading on Euro oils here and have learned a lot.
For my engines, I believe that any 0/5w30/40 A3/C3 oil would be more than fine, so I'll likely just buy whatever I can the best deal on.
Thanks again for your feedback!
But this is an oil forum, so why not try to split hairs?
Oh, I'm totally willing to do that-- just didn't want to annoy you!
So, to elaborate into a little hair-splitting-- from what I've learned, I think I'm partial to the A3/B4 Euro oils. Compared to the C3, the A3/B4 oils have a little more of a gritty, old-school vibe to them.
Somehow, the 20-year-old A3/B4, BMW LL-01, MB 229.4, A40, VW502 standards with the higher zinc, etc. somehow seem more in tune with my 15-20 year old Ford Essex V6, the Grand Caravan 3.3l V6 and my L98 SBC.
Of course, I understand that "vibes" don't mean anything and there is no problem at all using C3 (which I'm doing now with the Euro L I got).
But, as you said, it's an oil forum-- feelings really mean something here! :)
For those older engines (including my BMW), it is absolutely A3, LL01, etc.
The L98 is even flat tappet-- so A3, LL-01, etc. really feels right!
After I got the Euro L, I was able to pick up some Valvoline 5W-40 A3 Euro for almost as cheap.
Just reading the old-school specs on the back of the bottle while thinking about my engines gives me the warm fuzzys! :D
I've been using Walmart Supertech or Costco full synthetic in Ford and GM cars, in the mfr. recommended viscosity (0W20 or 5W30), for 20 years...OCI 5K miles...no engine problems. I'm in the Phoenix AZ area, so very mild winters and hot summers (110°+). I just bought a 2022 BMW 740i, 25K miles, with B58 engine, TU1 AFAIK. I'm expecting to drive the car ~4K miles per year and change oil 1x per year. I don't drive the car very hard. I don't know how long I'll have the car...in 5 years, I expect the car to still be at 50K miles or less. Would using Super tech/Costco Dexos oil in this car really make any difference in anything vs BMW LLxxx approved oil? Also, with our mild Winters and hot Summers, is the BMW recommended 0W20 best, or are xxW30 or xx40 more suitable?
Thank you for your opinions.
You’ll cook the motor. Only use LL01 or LL01FE.
Since you’re in Arizona I would go with a xx40 oil in the summer and xx30 oil in the winter.
If you’re going to use 0w20, just make sure it’s BMW LL approved.
The B58 engine in my late 2020 745Le XDrive has just ticked over 185k
Has its Service at BMW using 5w30 LL04, no Dealers that I have used supply the LL17FE oil during servicing, variable service interval but usually between 19000 and 20000 miles on iDrive
And I do 2 or 3 interim oil changes with either Castrol 5w30 LL04 or Shell 5w40 LL04 if I have time to order it from OpieOils or can find it locally.
Getting disposed of in November when it will likely have around 210k miles.
The engine still runs like it did when purchased at 26k, still uses the same amount of oil, still does the same fuel economy, performance seems the same but without proper testing couldn’t confirm or deny.
B58 really is a beast of an engine
Have decided my retirement car is going to be an M140i or M240i with a B58
How many coolant hoses and OFH/Heat mgmt modules have you replaced?
None
Had a water pump replaced this week under Warranty so just £250 Excess to pay.
If I was keeping it for much longer I would probably have some of the plastic pipes replaced.
But I don’t have any leaks or coolant or oil.
I suspect there are less issues with the B58 in the PHEVs as in Traffic the engine doesn’t run, and it pulls away on electric.
Even when the HV is discharged as a little bit of Regen is enough to recharge the battery enough to pull away on electric.
I have had to fix three DRLs though, I remove the modules and dremel out the burnt plastic then take the DRL module off the heat sink and replace the heat paste as BMW put hardly any on.
Since I have done that no more yellow DRLs
On original discs though, 7mm on front pads, 6mm on rear pads.
Have had to have 2 rear wheels welded.
Massive improvement when I went from RF tyres to normal ones, I run Pirelli P Zero PZ4 in * MO spec
Car being disposed of early and being replaced with a ‘26 i7 M Sport
The old donkey still shines up like a new car
Why are you disposing of the car? Does that mean selling it?
It is a working vehicle not a personal vehicle, from which the full value has been extracted, once I am finished with a car I have no interest in it whatsoever so it gets disposed of in the easiest and most efficient way possible.
I assume you mean you have depreciated it with the chosen depreciation method on your business taxes? Because the disposing of used assets is an accounting term. So you're just going to sell it for whatever you can get? I don't know how it differs with IFRS but I imagine it's the same in the US where you have to report any gain from the vehicle but you just ignore that and don't do it and everything's fine. Or like here in Texas and likely elsewhere in the US you list the vehicle as gifted so you don't recognize revenue and the buyer doesn't pay taxes when registering it but they still pay you but in cash and spend it not deposit to keep every step of the transaction off the books.
B58 TU2 and some Pennzoil Euro L 5W-30, plus a Mann filter, and the B58 will rip effortlessly all day long in the mountains. What a satisfying engine...
Can only write the car down for four years.
This one is going early as nearly new BMW i7 are well priced at the moment as the LCi model has just been released.
I was invited to the BMW UK release event and to be honest there are improvements to the exterior but the screens inside the car are awful, the infotainment is from a lower spec BMW and looks like somebody stuck it on, the thin screen the runs the width of the windscreen looks weird and the screen on the passenger side dash!
Just why…
I prefer the pre LCi dash with a HUD
Financial no brainer for me though, £70k for the one I am buying or a new one for £120k, which will make me precisely £0 extra
