Big Ford EV Announcement Coming Aug 11th
I owned a couple of the 300/6. All mine came with the NP 4 speed. That engine came out in 1965 - along with the 240 - well outside my 40 year window.
I did not choose 40 years randomly.
I have a 65 Mercury half ton with the 240 and three on the tree. It’s still sitting out on the farm - I’d love to get it out to B.C. lots of fun driving that one around..,
The same people proclaiming "The Grid" is in poor health, EVs are the problem! at the same time believe government must provide "EV infrastructure" in the form of DCFC charging stations (The Gas Station Fallacy, that EVs need gas stations). Nothing is more harmful to "The Grid" than a DCFC charger suddenly throwing a 250 kW load on the grid. Conversely a Tesla Wall Connector on 240V 60A circuit draws 48A, a mild 11.5 kW over hours of easy to stabilize The Grid load.
The grid here in NY was in poor shape long before EVs existed. The green new pipe dream would only make it worse. IIRC my brother who retired from Con Ed about three years ago said the top brass claimed Con Ed was probably 25-30 years away from being able to support a changeover to EVs. Maybe now they'll be able to accomplish getting the grid ready because imo the changeover is going to be a lot slower now.
The Blue Oval SK battery plant is looking close to battery production.
I just went on Google Maps and Apple Maps. Satellite imagery shows massive clear cutting under CA power lines. Especially visible in northern CA where there’s actual forests. Southern CA is generally all desert, cities or farms. That’s so easily disproved…
They are doing it now after PG&E was found liable for not cutting underbrush contributing to fires.
As I said originally, PG&E can usually cut but is not allowed to bill as an operating expense.
Easy to say. How does one measure that? What units does one measure "grid poor shape" in?
What does your brother know about EVs?
Time of Use rates are updated quarterly at best. There not even remotely close to RTP.
You are confusing what is being done vs what the technology supports.
Your the one ranting about me wanting central government control on when you run your water heater, which is laughable, so maybe check your own comprehension.
You lust for European on-demand electric power pricing and do not see the association with government control over when one may use one's hot water heater?
Because decades ago the collective we decided that everyone should pay for the residential grid because everyone benefits - much like a road. In some states you can't disconnect from the grid even if you wanted to.
So now some small percentage of people - 1.4% of cars are EV - are adding loads to the existing grid to the point where its almost at peak. Different areas vary, but the older and more densely populated the area, the generally worse it is.
So the grid needs to be improved. So they want everyone to now pay for the 1.4% or whatever percentage of EV's will exist in the future. Thats not exactly equitable, that the 98.6% subsidize the 1.4%.
Wait a minute! This is what I say!
… and what happens when EVs make up 10 to 15% of vehicles on the road?
Major grid updates will be needed and everyone will have to pay UNLESS and I suspect people with EVs will incur surcharges to pay for it.
Yes, major expensive grid updates/upgrades taking years if not decades to complete. Especially in densely populated areas like NYC, where keeping up with electric demand during heatwaves can be problematic. Put 10%-15% EVs on the road is asking for trouble with the grid as it stands now. I was laughing when they wanted to go all electric in new buildings to phase out oil and gas for heating, hot water, and push for electric pizza ovens, lol. A little more thought should go into it before making those ridiculous claims makes more sense than trying to set unrealistic goals.
https://www.jalopnik.com/1930598/ev-transition-problems-automakers/
"Five years ago, most analysts assumed that EVs were heading toward critical mass and that once they consumed around 20-25 percent of the market, they would swiftly take over. That hasn't happened outside of smaller countries and China, and certainly not in the U.S., because going from a gas-powered car to an EV isn't an easy leap – it's more like a series of steps. You have to deal with charging, software issues, and variable battery performance in extremes of weather. You also have to spend thousands if not tens of thousands more dollars to buy an EV than you would on a traditional gas car."
My neighbor loves his 2018 or 19 M3. No issues other than brakes/tires.
You can pick up an M3 so cheap right now. 23-24's with 7-15k for around $35k. 0-60 in 3.1 seconds. Insane amount of power for the money.
I'm not fully sold on them but now is a great time to buy one.
Probably as much or more than you, he also knows about the NY grid and Con Edison. Especially since he spent over 20 years working for them, here in NY.
You didn't answer. And in doing so did answer that your brother doesn't know Jack.
I am a retired engineer for whom my daily driver has been an EV for 12 years. Often eat lunch with a manager who works for the local electric utility. "What is the big problem with EVs on the grid? Not knowing when 250 kW loads will suddenly appear." He said looking at the raw data for my account he can't really see the EV. Looks too much like a heat pump.
What about battery disposal issues? Is it an issue?
No. Those darned innovative capitalists will find ways to make money off used and depleted batteries.
Oh wait, they are doing that right now, if you'd bother to search.
One of the greatest utilizations of a used EV battery is to repurpose for home energy storage. An EV battery with 50% of it's original capacity simply has less energy density than it used to have, otherwise works just fine. Usually only one module goes sour so disassembly of the battery yields a number of high capacity modules to build home energy storage.
