Quote:
10/22/07 - Beta Sheta! Holy cow guys have you not read my original thread regarding the EaO's real world performance in a real live vehicle?? Lab Beta testing is just that.. There is no such thing as constant flow oil in an engine application. Our oil pressures, flow rate, and viscosities vary continuously, NOT like the laboratory constant temperature, constant flow, close to worthless results..
In my view, it is of much more value in real world results vs. someone's laboratory results... The tests have little real world relevance..
George Morrison, STLE CLS
Quote:
10/23/07 - Again, these 'laboratory' beta testing procedures have absolutely NO relevance to our real world of automotive engine oil filtratino: none.. If any information relative to to oil filters was anectdotal, it would be these 'lab'tests.
As I previously indicated, all beta testing is done with constant flow, constant velocity, constant viscosity. None of these conditions exist in our engines. Thus any results are simply not relative.
As example, I had occasion to take a name brand filter which had a 3 micron beta 200 rating and install it in a varying flow system, with both upstream and downstream particle counting. On startup the filter indeed returned a 3 micron beta 200+ filtration rate. The moment the flow and pressures were varied (it was a real, live working machine and not a laboratory), the filter returned a 3 micron 1.5 or so. i.e. the filter was worthless in a varying flow/pressure environment. The microglass element was so fragile that it ruptured with the first variation.
While I agree that lab testing is not real world, you can not completely dismiss those results as he does. None of us would get an airliner if the wing structure and fuselage had not been load tested, the avionics for navigation had not be bench tested, landing gear, hydraulics, fuel system, etc all lab tested. A standardized Beta Ratio test would tell you something (apples to apples for a set of conditions). I could say that I have used a microglass media oil filter many times (which I have) and never seen a media failure in my real world applications and thus totally dismiss his findings. But he found a set of conditions where media ruptured even though it has nothing to do with my applications.
For real world analysis for all to use you would have to create a matrix and then set up tests with so many variables such as engine, oil grade, oiling system, filter, temperature, etc that it would be impractical with respect to time and money. I for one would like to see standardized tests for Beta Ratio, flow rates, and bypass and have those numbers published for the consumer. Won't happen but I'd like to see it.
