I see no reason you could not make those look good with properly done rattle can.
I'd brush and 3m pad as much off as you can. Wipe them down with xylene, light very light coats of rust convertor.
Then very very light coats of a silver that you find looks close. Look close at the wheel paints by duplicolor and vht. Light coats so you don't get a run in the paint. Runs will make I look like a rattle can job.
Once clean, ive used the card trick, and wiped silicone on the tire AFTER the cards were in place so over spray does not stick.
https://www.amazon.com/Sherwin-Will...61127546&sprefix=wheel+paint+,aps,122&sr=8-16
