Originally Posted By: Powerglide
A Datsun/Nissan L Series six is considered "broken in" at around 150,000 miles. Very often these motors will run 250,000+ miles and can be LIGHTLY honed, re-ringed and run another 250,000 miles without an overbore. The blocks are HARD. The straight six has virtually no side load wear issues. The RINGS wear. The blocks do not. Can't comment from a used oil analysis prespective though. I never bothered to do it.
On my 76 280Z...the head came off at 150K for a freshening. The cross hatch pattern in the bores was clearly visible---having been done at the factory in 1975. FWIW.
Same experience here with the 510 and its little 1600 four. Virtually the same engine as the 240Z, with pistons, rods, timing chain/gears, oil pump, etc. being identical to the 2400cc six banger.
Had one 510 wagon overheat so bad we had to stall it to shut it down (woman driver). Pulled the head off, over 180,000 miles and virtually no ridge in the cylinders, original crosshatch still visible, etc. Did a valve job on it and put it right back together. This in a car with a 4.56 gear and no overdrive. ALWAYS wound out tight!
