That's my point timing belt equiped engines require more maintenace/repair. If you have to replace the timing belt 2 maybe 3 times over the life of the engine, I don't consider that high reliability, when various timing chain equiped engines like the Ford modular etc often never require valvetrain drive repair. Also just because someone never adjusted the valves doesn't mean the mechanical followers didn't need it.
To give timing belts a pass it's not that far different than giving a plastic intake manifold gasket that needs replacement a pass, or any other essential part made of rubber plastic instead of more durable material. You have to draw the line somewhere to call an engine most reliable. Most reliable should also mean lowest repair/maintenance. I can give distributor ignition parts maintenance a pass for an engine existing while others had reliable DIS, but I draw the line at valetrain drive and having to open the valve covers for valve lash adjustment.
