Okay. "Falsehood". Too strong a word. I'm tired, but willing to hear correction.
Here are references for "facts" (and my apologies to MolaKule and any others if the below is quoted leaving the incorrect impression):
Coolant Versus Sump Temperatures
Zoz, Steve, et. al., Engine Lubrication Model for Sump Oil Temperature Prediction
SAE Paper 2001-01-1073.
(Interesting Articles, 8/2003; paraphrase by MolaKule):
http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=4;t=000196;p=0
Quote from post:
" . . on the average, the Oil Sump temperature is always 1.2 to 1.43 times higher than the coolant temp".
Average Coolant Temperatures
(from, MOTOR Magazine, 8/2003; first page):
http://www.findarticles.com/p/articles/mi_qa3828/is_200308/ai_n9294683
"When we talk about engine operating temperature, we're referring to average coolant temperature. For most late-model engines, this is in the range of 230[degrees] to 250[degrees]F. Thermostats are engineered to open in the range of 180[degrees] to 200[degrees]F. Heat transfers to the coolant as it circulates through the engine and the radiator then maintains the 230[degrees] to 250[degrees]F average."
Engine Cooling by Motor Oil :
(from, Interesting Articles, 6/2002; comment by Molakule):
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=1;t=000068;p=1
" . . Heywood's book
on "Internal Combustion Engines."
He starts with 100% fuel power (Energy/time)
and split the figures up. Here is the SI engine
data:
Brake - 27% (power to road)
Cooling - 25%
Oil - 14%
Exhaust 30% (end quote)
I've found in a Google search a number of references to "30% of engine cooling", but they were secondhand on retail sites or by editorialists and without attribution; I have no acccess to SAE papers to properly support or disprove.
In the same thread there is disagreement on the heat transfer abilities of synthetic versus, but I have seen no argument on this board of the superiority of synthetics over dino past, about, 280F [defined extreme service]. A coolant system failure, partial or total, leaves the engine oil holding the bag. Thus the point about having a margin for neglect or failure of the coolant system.
As to cost of ownership, if I use the EDMUNDS "True Cost to Own" feature to view the cost of buying, financing, maintaining, repairing, insuring and paying miscellaneous fees (see methodology employed), then my total cost in cents per mile, or CPM, is .46 for a 2001 Dodge Ram 1500. A total of $34,000 by the chart given.
Oil changes, even at my current cost of @ $50 at 7-8,000 miles equals about $400. Cheaper oil and filter at 5m miles would be 12 at $250. A difference of what percentage of my total cost?
What would be the installed cost of a new engine? $4000? More, less?
Am I to believe that a dino can, even in "normal" conditions exactly match a synthetic in engine cleanliness given comparable conditions? I've certainly seen engines that have run in excess of 150m miles, but they were not ever as clean as the ones run on synthetic.
As for the intake system, a spoonful of grit is all it takes. Yet we spend more time arguing over a small difference in oils.
For me, as stated, it is: margin of safety in preventing engine damge; an insignificant cost difference . . . and dirt infiltration is worth a whole lot more time in investigating and correcting.
Falsehood? Where?
Synthetics are my preference and that is stated as such.
