Hey I gotta get my $0.02 in here too...What's the difference between a piston pin and a connecting rod journal?quote:
Originally posted by nickmckinney:
Another trick for bearings are half groove vs full groove, and/or the use of crossdrilled cranks.
Shaft diameter is paramount as well, you can run a much less clearance on a much smaller shaft obviously. Look at the tightness of a piston pin.
Piston pin might have 0.001" clearance and is not forced oil fed, and around a 0.75~1.0" diameter. Rod journal usually around 0.002~0.003", is forced oil fed through passages in the crank which itself feeds from passages in the main webbing, and they (rod bearings) are usually around 1.5"~2.5" diameter.quote:
Geometry can be dead on, and you still have to deal with surface finish. They're both important, along with all the other variables.quote:
Originally posted by 1sttruck:
Geometry is probably more important than surface finish' roundness, straightness, cylindricity, position, etc.
Look at how a SBC feeds the mains and you'll cringe.quote:
Especially since many cam in block V engines the same passage that feeds the cam bearing also feeds the main bearing.
Man you would hate to see some of the crank finishes I have seen on fresh rebiulds. Most are done with a high speed 400 grit cloth if they are lucky. For my own personal I take it another notch to 600 grit.quote:
Another important difference is that the connecting rod journal is rotating 360 degrees continuously in the same direction, whereas the piston pin is alternating direction of rotation about every 45 ( I guess) degrees of rotation. So it is a very different situation.quote:
That's why old time engine hackers swear by SAE 40-50s. Between clearances and surface finishes they normally see, they're not lying when they swear by those grades.quote:
