My daily driver is a 79 Subaru DL. I have it oil undercoated yearly, and wash it often in the winter. There are a few rust spots that require repair, but those same spots have been there for many years, since I bought the car. Very little of it is original. Many parts have been replaced with parts from different manufacturers or models of car. There are even some marine and aircraft parts mixed in. Engine is an EA71S, which is essentially the Subaru factory race engine for the FJ1600 (old Japanese equivalent to a Formula Ford car). Originally it had dual carbs but was missing its intake so it is running a Holley 1904 carb on a modified single carb intake. Other modifications include Denso alternator from a Suzuki Samurai, GM HEI ignition module and Ford TFI coil, Ford Racing 90 degree oil filter adapter, and 5 speed dog gear transaxle from a Subaru 1300G. Too many little things to count. At this point it's as reliable as a modern car or better. Manual rack and pinion steering, very easy to steer but not at all like steering on a modern car. Not biased towards going in a straight line but rather unstable, in a good way. Any kind of turn from any direction can be made lightning fast, with little force applied. I carry a small tool bag which has every tool necessary to repair anything on the car. I rarely need to use it for any more than a small coolant leak, loose wire, or exhaust gasket. It's a great car, I am planning on keeping it forever. Eventually the body will be restored as well. I'm planning on getting another car that's RWD, lightweight, and manual transmission. Have my mind set on a Cosworth Vega. Always wanted one, have done a decent amount of work on the engine, but swapped into a Chevette. I'd like to use the original fuel injection manifold but install modern injectors, a modern Haltech ECU, knock sensor, O2 sensor, TPS, MAP sensor, and coil per cylinder ignition. Obviously have Cometic make me a custom MLS head gasket as well. And I think it would be a wonderful car, having gotten rid of the analog computer and actually having modern controls on that engine. If you're not looking for one in perfect shape they're really not terribly expensive. $4000-8000 range for one that needs paint and interior work, but is running and driving fine. Another old car that I think you guys will get a kick out of is my friend's 82 Toronado diesel. Original 5.7 engine, never rebuilt, has over 600,000 miles on it. It does have ARP head studs installed, but the cylinders are factory size, and they still have near perfect crosshatching. Oil used way back when is unknown. Currently uses mostly Mobil 1 15w50 and 5w50, some Mobil 1 V Twin 20W50 as well, Mobil does strangely recommend it for API CF applications. Included are some pictures of my Subaru:
View attachment 183919View attachment 183920View attachment 183921View attachment 183922View attachment 183923View attachment 183924
