A proper alignment would be money better spent and then you wouldn't NEED to do rotations. Trying to imagine which of the four cars you have listed take tires that cost $400 each?I just paid $40 - replacement tires will be $400 each …
That and stop going around corners …A proper alignment would be money better spent and then you wouldn't NEED to do rotations. Trying to imagine which of the four cars you have listed take tires that cost $400 each?
Definitely. I'm religious about it. I also do a decent amount of highway miles and rarely corner or brake hard. I've never NOT gone well past the mileage warranty and still had 3-4 32nds left.Every 5-6K, or at the minimum, every oil change. IME it really helps improve longevity since the front and rear tires wear at different rates. It also gives you an opportunity for a brake inspection.
I buy 60k or more warrantied tires. And often get 65-75k out of them and still have 3-4 32nds left. I rotate about every 7500 miles. Always have. From Firestones, to Goodyear's, to Michelin (what I often buy) I've always gotten the mileage warranty and never had issues with tread wearing oddly. I also check with a tread depth gauge once per month or so to make sure they're wearing evenly, too.I do rotate tires occasionally, but I’m not obsessive about it. I think a tire rotation every 10k miles or so is more than enough. Might work out to 3 or 4 rotations over the life of the tires.
Probably the most important part of a tire rotation is the opportunity to inspect the tire for safety issues.
Are there any tire stores (chain or local) that don't rotate for free if you purchased them there?I forget who, but someone on YouTube once calculated the economics of rotating tires...basically, unless you do it yourself or can have someone else do it for 'free' (say as part of an oil change service), then it is actually cheaper to just let the tires on 1 side (front or back) wear out and just replace those 2 tires when needed. Now this was a few years back and I believe they assumed a $25 service charge for tire rotation. Personally, I rotate my tires every 5-7k miles...either myself or part of a service package.
You go right and you go left. It should pretty much even out. Well technically, 51% percent are right turns, but not enough to worry about.
They can void your warranty if you don’t …Are there any tire stores (chain or local) that don't rotate for free if you purchased them there?
This and warped rotors are why I chose to rotate at 24,000 mile intervals instead of every oil change etc…Nobody is concerned about wearing out the wheel studs every time a wheel is removed and installed? I'm surprised nobody brought that up know how OCD some BITOG members can be about stuff like that.
