I'd like to try and get down to buying just one of these filters if possible. Is the XG7317 just slightly larger?
Thank you for the insight of this group.
The 7317 is also wider than the 6607. I used them interchangeably on my wife's former vehicle, a Mitshbishi Outlander, but when I tried to put a 7317 clone on my sister in law's Honda Pilot, it was almost too big for the engine side of the filter base. Any wider and the gasket would have been over the edge. The 6607 is a better choice for a Pilot.
| SKU PH7317
More Information | SKU PH6607
More Information |
On Nissans, it seemed like on all "cars", they spec'd the 6607 and for trucks, SUVs, etc they spec'd the 7317. My G35 calls for a 6607 but I've used a 7317-size filter for as long as I've owned it (mostly because our Hondas use a 7317 so I just buy one size for all).My Nissan Frontier with the 2.5 liter engine is an example of that. The V6 engine fits the 7317 while the 2.5 liter I4 engine fits the 6607 because the 4 cylinder engine places the filter too close to a suspension component.
I've seen this with shops, quick-lubes, etc as it's one less filter they need to stock. Even Supertech eliminated the 7317 from their oil filter line-up, which I was disappointed about. If you use their look-up tool for a Civic, for example, they'll tell you to use a 6607. I'm sure there's zero issue as well.Some vehicles don't have room for the taller 7317 so they specify the 6607.
What vehicle ? Well, unless it's one of the few I'm familiar with, the answer might not help. Is there plenty of room where the oil filter sits ? Even "plenty" of room is probably overkill. Very good chance a 7317 will fit. The critical dimensions being the threads and o-ring ID and OD are a match though.I'd like to try and get down to buying just one of these filters if possible. Is the XG7317 just slightly larger?
I've installed many 7317 filters and mostly removed some 6607 and 'never' noticed the former to be "wider" than the latter.' All my comparisons and filter specs show same OD with similar/same gasket dimensions. It reads like you may be confusing the 7317 application with the 9688 used on older pre-2001 Hondas. The 9688 is shorter but wider than the 7317, and will NOT fit many/most Honda now because or engine block or oil pan restriction.The 7317 is also wider than the 6607. I used them interchangeably on my wife's former vehicle, a Mitshbishi Outlander, but when I tried to put a 7317 clone on my sister in law's Honda Pilot, it was almost too big for the engine side of the filter base. Any wider and the gasket would have been over the edge. The 6607 is a better choice for a Pilot.
I have 2 of the 3 same models. Buy 7317-size filters.I maintain a Honda Civic and a Infiniti G35 & Mazda 3
The XG6607 filter media is short, and the surface area is considerably smaller.A small increase in the height of the filter can make a big difference in the amount of media the filter has. For example, the Supertech MP7317 has over 70% more media than the MP6607 (95 in^2 vs 55 in^2).
All else being equal, the 7317 would have a much higher holding capacity and better bypass resistance. The efficiency should even be a bit better due to lower flow velocity and less dirt loading. I would always use the 7317 if there's enough room.
LOL That sounds like what someone working at a quick lube might say. And in the case two topic applications, most likely the 6607 is what they got, and will be used for the spec 7317. I've even seen several ql anecdotes posted here where 6607 used for spec 9688.Years ago an old friend of mine worked at a quick lube. He told me whatever filter fit is what you got.
Yes-my first & last trip to Jiffy Lube with the company Transit got a jobber 2222 in place of the FL910S size it should have gotten. Maybe 2/3 the size.LOL That sounds like what someone working at a quick lube might say. And in the case two topic applications, most likely the 6607 is what they got, and will be used for the spec 7317. I've even seen several ql anecdotes posted here where 6607 used for spec 9688.
