I posted a FAQ from radio mechanic Mark Salem elsewhere-- primarily to drive Rando up the wall.
Here's another quote where he seems to state that oil filters are designed for a manufacturer's weight recommendations:
" So in conclusion, if the car maker says use a 5/30 engine oil and the oil filter maker knows that, they will make the filter based on the properties of 5/30 oil. If you use a 10/40 in an engine where 5/30 is recommended, you will not get the protection you want and that heavier, peanut butter like oil will cause additional wear to your engine. 040399 "
http://www.salemboysauto.com/faqs/faq-30.htm
