Isn't OP driving an F150 V8? My last Ford truck filter held close to a quart,What filter holds a quart?
https://bobistheoilguy.com/forums/t...-amsoil-eao11-capacities.104519/#post-1420043
A 450 HP Cummins….!Isn't OP driving an F150 V8? My last Ford truck filter held close to a quart,
Nope,A 450 HP Cummins….!
To give vehicle background: 2016 F-150 with the 5.0.
Yes, F150 V8, but not the one in that picture. That could be a 5.4. Side note: I would kill for my filter to be in that placement, LOL.Isn't OP driving an F150 V8? My last Ford truck filter held close to a quart,
So you are going to the trouble of changing the oil but will leave nearly a quart of the old dirty oil to mix with the new oil? I'd say, why bother even changing the oil then. The gasket on the filter is rubber, it's not a head gasket. If it can't be tightened a second time, it's a garbage filter to begin with and should just be changed now.
Well sure, they want you to buy a new filter and not reuse the old one.Find us one oil filer manufacture that claims it's acceptable to remove and reinstall an oil filter. None will put their name on that, at least not in writing.
You can do as you please, but if the gasket can't take being tightened a second time, its either already leaking, or it's a poor quality filter.The reality is that it's an unnecessary risk. Once the filter is installed and properly sealed - leave it until it's to be replaced.
What seal being broken? By that argument, it would be leaking before it's even removed.I see it as a matter of risk and liability for the company. As the rubber experiences heating and cooling cycles, coupled with the seal being broken, it's a gamble to reinstall and hope it seals again.
I have had, to my knowledge, 3 cars with owners manuals recommending an FCI every other OCI.Well sure, they want you to buy a new filter and not reuse the old one.
Is this the correct filter for your truck? We use these on expeditions and F-150’s at my work.Yes, F150 V8, but not the one in that picture. That could be a 5.4. Side note: I would kill for my filter to be in that placement, LOL.
FL-500S is the OE filter recommended for my 5.0 Do not know the capacity of it as I have never used one.
I did just put a FE10575 on my wife’s Acadia last weekend and pre-filling it (since it hangs like the Ford above) took just shy of a 1/2 qt after waiting for the media to soak up what was poured in multiple times.
I wouldn’t think that 1/2 inside the filter would have much affect on the next fresh 7.7 qts coming in.
But that seal is reestablished once the filter is screwed back on. It is a rubber gasket after all. If you're suggesting the gasket has turned hard and has cracks in it causing leaks, that's a different scenario. They may get hard and brittle after years on the car, not months between oil changes.By seal, I mean the bond created between the engine and oil filter gasket. In other words, what keeps oil from rushing out.
With the filter removed, this seal is broken and must be reestablished once reinstalled.
https://i.ebayimg.com/images/g/bEgAAOSw4RxgprFY/s-l1200.webpWhat filter holds a quart?
The FL820S doesn't hold a quart of oil, lol. Oil filters are not totally hollow. The guts of an oil filter takes up quite a bit of volume.Isn't OP driving an F150 V8? My last Ford truck filter held close to a quart,
Honda allows oil filters to be used over 2 OCIs per the OM maintenance schedule.I see it as a matter of risk and liability for the company.
Compare the base gasket on a used filter to the same filter that's never been used. The base gasket compresses and remains compressed on the used filter, so if you remove it and reinstall it, the gasket doesn't have much spring action left in it. If someone is going to run a filter for more than one OCI, don't remove it, drain it and then reinstall it. Don't disturb the gasket is the best practice. Why go through all that trouble and risk to drain 6 or 8 ounces of oil from the filter?But that seal is reestablished once the filter is screwed back on. It is a rubber gasket after all. If you're suggesting the gasket has turned hard and has cracks in it causing leaks, that's a different scenario. They may get hard and brittle after years on the car, not months between oil changes.
Yes, absolutely. My comments are toward the idea of removing and reinstalling an oil filter only.Honda allows oil filters to be used over 2 OCIs per the OM maintenance schedule.
