Originally Posted By: boraticus
Originally Posted By: bigmike
Well, if it were down here, I'd run Delo 15w40 or straight Pennzoil conventional HD30. I suppose you might need a lighter weight in case you run it in winter. I'd be tempted to go with Chevron Delo 0w30 or 5w40, or Rotella 10w30.
I agree with the above. If the machine is kept in heated storage, you don't need oil for cold start applications. Once it's running, it's at operating temps.
Lots of fretting over a simple little piece of OPE. My Champion came with an excellent manual. It recommends 5W30 for temps below 0 deg. F and 10W30 for temps above. It's got virtually the same engine and I'm running Shell 10W40 in it.
Why? Because that's what I had near by when I did the oil change.
By the way, when I did the 5 hour oil change, this was probably the cleanest engine I've ever worked on. I drained the oil through a coffee filter and there was no visible particulate in the oil. I was impressed with that.
Champion and Lifan do not use the same engine. They may be similar but they are not the same thing. Champion builds their own engines( in China at their plant )for the most part although I have heard of them using some Kohler engines on some things. Lifan builds their own engines as well.
Quote:
Champion Power Equipment was founded in 2003. We are a US owned and operated company with our own manufacturing facilities in the Zhejiang province of China.
http://championpowerequipment.com/
I can't go by the manual from a different brand. My Lifan generator and your Champion generator are not the same thing so your owner's manual oil recommendations don't help me out much. This isn't a situation where 2 different items are the same thing under different brand names like Wix/Napa Gold oil filters. 2 different generators.
I need to go by the manual from my generator's mfg. I am happy your Champion manual is good. Doesn't help me with my Lifan. My generator comes with a 3 year warranty not a 1 year like most others. I want to be sure I follow Lifan's guidelines. I realize it is "just oil" but I want to use the right stuff. I want to here from them that it is ok to use SL or SM or SN not just assume. It isn't fretting over something silly it is due dilligence.
This generator will be kept outside in my unheated shed and mainly called upon during winter power outages. A 15w40 is not in the cards. A 5W or 10w30 is what I need and probably an SL will be what I use.
