I bought by mistake straight weight 30 Ace hardware oil can I use it in a Honda lawnmower engine that calls for 10/30. Engine about 14 years old uses no oil.
What is it rated? is it HD or ND? if ND then NO. Could also be API SAE 30 with current API S -service category then that is O.K. also,I bought by mistake straight weight 30 Ace hardware oil can I use it in a Honda lawnmower engine that calls for 10/30. Engine about 14 years old uses no oil.
I have some ST SAE30 that is SP …What is it rated? is it HD or ND? if ND then NO. Could also be API SAE 30 with current API S -service category then that is O.K. also,
I would not run something without certs or approvals on the back label regardless of ad text, I know ACE sell some of this stuff.
- ARCO
I have to look at the rating it's new stock so probably up to current standardWhat is it rated? is it HD or ND? if ND then NO. Could also be API SAE 30 with current API S -service category then that is O.K. also,
- ARCO
Don't assume it's even for internal combustion engines. As Arcographite said, if it's not API rated then don't use it. There is a slew of ND30 oils out there that look like motor oil but they're for vacuum pumps and other devices that don't require a detergent or anti-wear package.I have to look at the rating it's new stock so probably up to current standard
Is it ACE labeled lawnmower oil or a major brand?I have to look at the rating it's new stock so probably up to current standard
HD30 - YES/JA/DA
ND30 - NO/Nein/Net
If the bottle looks like this and it is number 8706723 then DO NOT use it:
That's exactly what I have scored on sale $1.99On the other hand, if it looks like this:
Ace SAE 30 4-Cycle Motor Oil 1 qt 1 pk Mfr# AH0230P6 - Ace Hardware
ACE heavy duty motor oil contains a new detergent additive to prolong engine life. Complete engine protection to minimize wear.Find the MOTOR OIL SAE30HD QT ACE at Ace.www.acehardware.com
Use away. It'll be just fine.
It will work fine in your Honda.I bought by mistake straight weight 30 Ace hardware oil can I use it in a Honda lawnmower engine that calls for 10/30. Engine about 14 years old uses no oil.
